That'll be right RichardRichardW wrote:Just like most other jobs on PSA cars thenCitroJim wrote: Like me I expectMuch profanity, big hammers, punches (not of the Karate variety), cold chisels and angel grinders...
HELP stuck front wheel bearing circlip!!
- x 8423
Re: HELP stuck front wheel bearing circlip!!
- x 94
as i said above but now also belowRichardW wrote: I wonder how garages deal with them?
citronut wrote:i use the pointed end tang of a large old file to pries one end of the circlip out, then get a thin screw driver blade in between it and the hub carrier,
this gets most of these circlips with no eyes out
Regards, malcolm.
ecohouse1
- x 3
UPDATE HELP stuck front wheel bearing circlip!!
Thanks Guys - just by way of an update, I took the ABS sensor bolt out & shifted the heatshield on to the top, thereby letting the sensor get 1mm closer to the reluctor ring. The ABS wierdness has now stopped so thanks for the advice.
Cheers
Alan
Cheers
Alan
- x 8423
