Cloudy headlight lenses
smoker
Unread post by smoker »
Hi again. The headlight lenses on my recently acquired '02 Xsara 110 are cloudy. This was noted at the last MOT. I've gone over them with white spirit/cloth and removed a fair bit of brown looking residue, but they are still not as clear as other cars' lenses. They almost look like plastic that's had too much sun, yet I'm sure they're glass? Any ideas on causes or rectification?
Cheers all
52 reg Xsara 110 hdi
wurlycorner
x 271
Re: Cloudy headlight lenses
Unread post by wurlycorner »
Don't know Xsara's, but I assume they're polycarbonate (plastic) lenses?
If so, that's a common affliction with modern cars and the cure is... Yes believe it or not... sandpaper and T-cut!
Here are a couple of guides;
http://www.detailingworld.co.uk/forum/s ... p?t=229157" onclick="window.open(this.href);return false;
http://www.preludeonline.com/f65/headli ... cs-238137/" onclick="window.open(this.href);return false;
You don't have to go to the expense of so many different polishing solutions after the sanding, people do get away with just one.
If they're not polycarb headlights, then ignore this answer of course :lol:
Iain
CX DTR T2 Safari (silver)
handyman
Unread post by handyman »
Try toothpaste as a polishing compound before you use any other abrasive. 8-[ I use it to clean grime off windscreens. Works a treat & smells nice & minty, even on my gnashers. :-D
H
addo
Sara Watson's Stalker
x 95
Unread post by addo »
So you smear it all over the glass and lick it off? :mrgreen:
I'd think there's a market for chocolate scented car wax...
SaabC5
Unread post by SaabC5 »
Spot on by Handyman, try a whitening compound toothpaste, the micro crystals in the tootpaste bring up polycabonate headlights a treat. :mrgreen:
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
waynedance
x 8
Unread post by waynedance »
We use G3 at work, works a treat but as said T-Cut is a good alternative.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
x 3298
I believe that an Australian dentist is working on a formula for chocolate flavoured toothpaste, to try and make children clean their teeth more!
x 94
Unread post by citronut »
i have heard if you gently wave an electric hot air paint stripper at them it turns them clear again,
its also mean to work on plastic bumpers when the fade,
i have never tried it myself though
Regards, malcolm.
addo
x 95
That's a fairly temporary fix. Polish plus nano sealant is probably the simplest option.
smoker
Many thx for replies. Was thinking along the T cut lines but was worried about scratching or causing swirls. Reassured now tho' and will give it a go.
Cheers
