Hi
I have a Xantia 2.0 make year 2000 with auto gear box AL4. I notice that there is ATF leak where the gear box is attached to the engine. I guess there is an oil seal at the converter. I browsed the Citroen service for the part number but could not find it. Any one knows if there is an oil seal and its part number. Any idea for the leaking ?
Zohar
Xantia - Part number of auto gear box oil seal
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
- x 8
Re: Xantia - Part number of auto gear box oil seal
Is this is the part 226430 ?
Zohar
Zohar
addo
- Sara Watson's Stalker
- x 95
Hi Zohar, be prepared that it could be leaking because of wear to the input bushings of the gearbox.
http://www.sonnax.com/units/231-DPO" onclick="window.open(this.href);return false;
lancia58
- x 8
Hi Addo
Can you please post Citroen part number so I can find it on Ciroen service ? Does this involves with taking apart the gear or just remove the gear box from the engine bay
Thaks
Zohar
Thaks
Zohar
- x 94
if you post the last 8 digits of your chassis/VIN No. others could check on service citroen to see if they can find it also
Regards, malcolm.
addo
- x 95
lancia58
- x 8
Hi
This is the rear engine oil seal ?
0127 28
Can the 226430 and 221225 be the source for the leaking
Zohar
0127 28
Zohar
