Think I may have found the reason for my persistent squeaking from around N/S front door. It seems to have a few of the door card plastic clips broken.
Can anyone tell me where I can buy replacement clips without going to a main stealer?
Cheers.
C5 Mk3 Tourer door card plastic clips
bigblackfalco
- x 11
58 plate (2009) C5 Tourer 2.0 HDi VTR+
- x 3306
Re: C5 Mk3 Tourer door card plastic clips
Those clips shouldn't be THAT expensive. I had to buy a few 'hog rings' for exterior trim, and they were only pennies (cannot remember how many, but not enough to put me off).
vborovic
- Locked user account
- x 40
There should be two types of clips which are mounted to hold the door cover (depending on the position on the door), one is 00009341PF and the other 00006991S9, approx. prices per my knowledge (if the part numbers are correct) should be 2.52€ & 0.38€ at most (per piece), the only possible problem if they come in packs of X pieces, whether the dealer will sell you 1-2 (and they keep the remaining in their supply), or you'll be forced to buy the whole package ... I usually get away with getting just the amount I need, with my dealer keeping the rest ...
The clips should look like this, right (hopefully I got it right, that which you're looking for)?
bigblackfalco
- x 11
Yes those look similar, although I'm not sure which ones exactly.vborovic wrote:There should be two types of clips which are mounted to hold the door cover (depending on the position on the door), one is 00009341PF and the other 00006991S9, approx. prices per my knowledge (if the part numbers are correct) should be 2.52€ & 0.38€ at most (per piece), the only possible problem if they come in packs of X pieces, whether the dealer will sell you 1-2 (and they keep the remaining in their supply), or you'll be forced to buy the whole package ... I usually get away with getting just the amount I need, with my dealer keeping the rest ...
Guess if I go to the main stealer at least I should be given the correct pieces.
vborovic
- x 40
If it helps ...
bigblackfalco
- x 11
It does. Thank you very muchvborovic wrote:If it helps ...
