sphere supplier
- x 94
sphere supplier
http://www.sphere-shop.co.uk/" onclick="window.open(this.href);return false;
Regards, malcolm.
- x 8422
Re: sphere supplier
Excellent Malcolm, thanks for posting that
That they sell spheres for Peugeots may cause some a little head-scratching..
10 points for the first person who can name a Peugeot equipped with hydropneumatic suspension...
OnlineHell Razor5543
- x 3296
Re: sphere supplier
Doesn't the 406 coupe have some sort of weird suspension on the rear?
- x 8422
Re: sphere supplier
Yes, it's called coil springs JamesHell Razor5543 wrote:Doesn't the 406 coupe have some sort of weird suspension on the rear?
- x 3296
Re: sphere supplier
I heard tell that one of the Pug 4 coupes' had a hydraulic system of some sort on the rear suspension, and it required careful handling when it was jacked up. Somebody I knew had issues with his when it had been lifted on a two post lift; it threw the suspension out and had to go into Peugeot to be sorted out.
- x 8422
Re: sphere supplier
It should have as the Pug 406 Coupé was originally destined to be the Citroen Activa...Hell Razor5543 wrote:I heard tell that one of the Pug 4 coupes' had a hydraulic system of some sort on the rear suspension
Sadly it never happened...
Northern_Mike
Re: sphere supplier
405 Mi16 4x4.CitroJim wrote:Excellent Malcolm, thanks for posting that![]()
- x 94
Re: sphere supplier
Mike's hit the nail on the ed
it was in deed the 405 M16 4X4
which apparently had the BX rear axle, so just the rear end was hyd your haw locks= hydraulic
Regards, malcolm.
- x 8422
Re: sphere supplier
Correctnorthern_mike wrote:405 Mi16 4x4.CitroJim wrote:Excellent Malcolm, thanks for posting that![]()
Correct!citronut wrote:Mike's hit the nail on the ed
