drive belt 110 hdi xantia t reg
jacksun1987
Unread post by jacksun1987 »
Just wondering if you can take the drive belt off with out taking the wheel off ?
As i lost the key lock in wheel nut
Its looking bad need it done asap. Seem to be i line going though the middle of the belt. Where its starting to crack.
thanka
x 8391
Re: drive belt 110 hdi xantia t reg
As the tensioner release is accessed from the top of the engine I reckon it should be possible with a bit of fiddling...
rory_perrett
Unread post by rory_perrett »
Yes you can, it would help if you can get the car up on ramps so you can get at the crank pulley from underneath. Don't leave it if you know it's bad. I've had 2 engine failures caused by bits off the auxiliary belt finding their way into cam cover and causing the cam belt to jump a few teeth.
isisalar
x 3
Unread post by isisalar »
Mine's looking a bit suspect too, could anyone say how many hours labour a garage would charge to change the belt?
Here's some pictures https://www.dropbox.com/s/u499zbpim6zgs ... .32.43.jpg" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/p8ef31dywtrj4 ... .32.28.jpg" onclick="window.open(this.href);return false;
Do I need to get this done?
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
x 8391
isisalar wrote:Mine's looking a bit suspect too, could anyone say how many hours labour a garage would charge to change the belt?
If they try charging for more than an hour Paul then they're having a laugh...
isisalar
x 3
Thanks Jim, I'll see what BL auto's say, it's in there on Tues. for some work. I've posted up some pictures since your reply, would value your opinion.
Cheers
Paul
x 5672
If it is any help, I had my alternator pulley (free-wheel device), camshaft pulley (dual-mass) and the belt changed for £163 including parts.
x 1488
Difficult to tell from your pics Paul - you really need to see the inside of the belt where it is wrapped around the eccentric tensioner pulley. If the V grooves are well cracked then replacement beckons. It's not too difficult - pop out the engine ECU, remove the box (2 10mm bolts in the bottom), lift the tensioner (15mm spanner :roll: ) and pin it back - 4mm bar in the hole. Remove the belt, feed the new one in, put the tension back on, replace the box and ECU. Easy < 1 hour -BUT it might be necessary to adjust the eccentric tensioner to get enough tension or to get the belt back on, depending on how tight the old one was. This needs access from under the wheel arch, but to answer Jacksun's point, it could be with the wheel still on - suspension in high and full RH lock, but it would be a bit awkward!!
x 8391
Looks quite an elderly belt Paul.. As Richard says, without seeing the V grooves it's hard to tell but judging by the outer appearance I'd be inclined to swap it just for peace of mind...
isisalar
x 3
Thanks Guys
With that BUT, I think I'll leave the job to an expert Richard, the advice much appreciated.
Elderly belt will be replaced Jim.
Cheers
Paul
