And we're back but...
- x 8378
Hi all,
We're back on-line but running on a contingency server restored using Friday backups so some stuff might be lost.
The normal production server has failed and as Xac is away for a week on holiday and could not resolve the problem remotely we took the decision to bring up the contingency which normally hosts the test forum.
It may not be as fast as it's running from my house and my Internet is not that fast. It's running on Apache under Linux on a not very powerful server rather than a beefy Windows Server as it normally does.
We'll advise later when normal service will be restored but it won't be until next week at least...
dnsey
- x 19
Re: And we're back but...
FWIW, Jim, the Forum is currently considerably faster for me than it has been of late!
Had the main server been slowing over the past few weeks for some reason?
- x 5673
I find the same Jim, noticably faster on your server.
- x 8378
Ohh, that's interesting about the speed.... My Internet is quite slow too...
And the server is only an old HP desktop....
Must be the Linux doing it...
BX Club is now back with us too...
- x 1240
Its a lot faster than the other one Jim - even when it was working.
sparksie
- x 33
Yes, here in the land that time forgot, in rural Ireland, speed is much improved too.
Maybe I've been bombarding my ISP unfairly, over the slow internet speeds.
This is great, right now...
Sparksie
2000 Xantia 1.9TurboD
Old-Guy
- x 24
Can confirm that the Forum server has been slow of late, compared with almost any other site. Was having problems with my broadband - kept blaming BT Openreach - turned out to be yet another failing AC (switched mode) adaptor. I've had a number (mine and various customers') fail in the last 2-3 years. Mostly just died, but a couple (one Linksys and now a Belkin) that went 'soft' - when the router started working hard for its living, the AC adaptor couldn't supply the current, with the result that the connection would drop out. Did the usual test of connecting a completely different set-up of new or known-good units directly to the Master Socket - fine, a blasting 16Mbps. Started eliminating links in the chain one by one, when I got to the original router (and its AC adaptor), the router's boot sequence halted with all the front LEDs flashing in sequence. Fortunately the AC adaptor for the spare router was compatible - problem solved.CitroJim wrote:Ohh, that's interesting about the speed.... My Internet is quite slow too...
Must be the Linux doing it...![]()
Of course Linux is sooo much faster (and reliable) than Windoze.
macAU
I've reached my monthly download limit and am now having my speed throttled back but this page loaded quite quickly compared to others.
1924 5CV 'la petit citron', 1970 Citroen DS21 Pallas, 1973 Citroen D Super 5
1981 Citroen CX 2400 Pallas C-matic, 1981 Citroen CX Reflex 'Familiale' 2400 ZF auto
1981 Citroen CX Super 'Familiale' 2400 C-matic, 2011 Citroen C5 and a 1991 Mazda E2200
- x 8378
Excellent news on the speed folks
Some of you may have experienced problem logging in whereby you were told you’d exceeded your login attempts and you found you needed to solve a CAPTCHA to log in.
This problem is now foxed...
It was caused by the fact that the forum server proper sits behind a proxy.
Xaccers
- x 188
The speed issue were issues with the main server's internet connection, for some reason despite the router reporting decent connection speeds the actual bandwidth available was dropping rather low.
DIY sphere tool
DIY sphere tool
Welshy_Pete
Same here its much faster now.myglaren wrote:I find the same Jim, noticably faster on your server.
citroenxm
- Fallen Hero
- x 70
Far faster for me too!!!
Was beginning to loose hope, it was so slow, it was no fun looking about!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
electronmirror
- x 31
......and another one.
Much quicker in all respects than the main server.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
lexi
- x 134
Apart from all that Jim, I demand to see you back on the forum on regular basis..........please?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8378
OK, arm twisted. Demand met. I'll be around a bit more from now on...lexi wrote:Apart from all that Jim, I demand to see you back on the forum on regular basis..........please?
