Xantia Mk1 bumper studs
Xaccers
x 185
Unread post by Xaccers »
Had a bit of an "oh bother" moment on the way to work as manoeuvring off the drive the bumper caught the edge of the fence which juts out and pulled it off.
Can someone with more skill with citroen service tell me the part number of the studs, or post a copy of the repair of them (which is in the subscriber section)?
DIY sphere tool
KennyW
x 163
Re: Xantia Mk1 bumper studs
Unread post by KennyW »
Xac,
Is it estate or saloon front or rear or Both :!: I've copied them and can post the lot if you wish
Kenny
C3 1.4 petrol (SWMBO)
KennyW
x 163
Xac,
I've posted the links below hope this helps.
file:///C:/Documents%20and%20Settings/kenneth%20welsh/My%20Documents/Car%20Documents%20etc/XANTIA%20-%200290%2006%20617615%20-%20REAR%20BUMPER.htm
file:///C:/Documents%20and%20Settings/kenneth%20welsh/My%20Documents/Car%20Documents%20etc/XANTIA%20-%200290%2006%20617620%20-%20REAR%20BUMPER.htm
file:///C:/Documents%20and%20Settings/kenneth%20welsh/My%20Documents/Car%20Documents%20etc/XANTIA%20-%200290%2006%20617515%20-%20FRONT%20BUMPER.htm
file:///C:/Documents%20and%20Settings/kenneth%20welsh/My%20Documents/Car%20Documents%20etc/XANTIA%20-%200290%2006%20617510%20-%20FRONT%20BUMPER.htm
XANTIA - 0290 06 617610 - REAR BUMPER.htm
Kenny
They've not worked bother :oops: Hope the numbers are useful, I'll figure out what I've done wrong.
Xaccers
x 185
Front bumper Mk1 estate
DIY sphere tool
Xaccers
x 185
Kenny, cheers for trying, those are links to files local on your computer only accessible at your computer :)
I've had a look in the rain tonight and one stud is in place, the other has been ripped out so I'll have to look into fitting that back on, I can't see any access to behind (maybe under the headlamp) or I'll just use a larger washer.
Wife's found a primered bumper online for a reasonable amount so we'll order that and I should be back on the road in time for my birthday :)
DIY sphere tool
KennyW
x 163
Xac,
Sorry I was back shift yesterday so just checking now. Yes you are correct it s files for sharing on my computer alone. I'll get photo to you later.
Kenny
KennyW
x 163
Xac,
I hope these help
Kenny
Xaccers
x 185
Thanks Kenny
DIY sphere tool
KennyW
x 163
Xac,
If you want the part numbers I have them but can't get them onto the forum for some reason.
Kenny
