Xantia HDI 110 Mintex Discs / Pads
XantiaExclusiveHDI
Unread post by XantiaExclusiveHDI »
Hi all :)
Can anyone confirm if these are the correct pads & discs for my car which is a year 2000 HDI 110 Exclusive:
http://www.ebay.co.uk/itm/CITROEN-XANTI ... 3cd86b7566
Also what people's experience of these Mintex parts might be?
Thanks!
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
electronmirror
x 31
Re: Xantia HDI 110 Mintex Discs / Pads
Unread post by electronmirror »
Yes, those are the correct pads and discs, I have the same model Xantia.
I've used Mintex pads and discs in the past on this car and found them to be very good. That's a good price for quality pads and discs too, wish that offering had been around six months ago when I did my front brakes.
Do remember that the caliper pistons must be turned at the same time as being pushed back into caliper body.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
XantiaExclusiveHDI
Thanks!
Yes I've read the various tricks used to wind the pistons back in :wink:
Currently:
Previously:
BX 19 TZD Turbo
XantiaExclusiveHDI
Just to check they are the same for the saloon & the estate? I ask as you mentioned you had the same model - but your car is an estate?
Thanks again!
Currently:
Previously:
BX 19 TZD Turbo
electronmirror
x 31
Yes that is the correct type.
The 110 bhp Xantia whether estate or hatchback uses the 288mm diameter disc. It's worth measuring the discs you receive because some motor factors/dealers have been known to incorrectly state that the 283mm dia. disc is for the 110.
Ted
