Xantia hydraulic pipes removal
fangorn
Unread post by fangorn »
How an earth can I detach pipes from metallic support shown in attachments ? I´m trying to replace feed pipe to back suspension,,,
KennyW
x 163
Re: Xantia hydraulic pipes removal
Unread post by KennyW »
Fangorn,
Have a read of this ongoing thread which may help
http://www.frenchcarforum.co.uk/forum/v ... =3&t=47780" onclick="window.open(this.href);return false;
What type of Xantia is it :?:
Confirm the return pipe to the LHM tank.
Kenny
C3 1.4 petrol (SWMBO)
fangorn
KennyW wrote:Fangorn,
Kenny
Thanks Kenny !
My Xantia II is just a very common 1.8 16V Break, year 1998. I already decided to use method "brute force" and pushed the plasctic clamps holding plastic pipe holders/clips connected to that metal "thing" through metallic support holes.
Now I can access plastic pipe holders and change pipe. I really can´t understand why those pipes aren´t attached straight to the frame as in other cars !!
c.morewood
x 55
Unread post by c.morewood »
I used a long flat screwdriver to get to the hard to reach ones.. I'd advise doing the no.9 pipe as well. since you'll have all the underneath off..Put mine back on today.. a bit of a hassle with the very front clips on the undertray and getting the pipes in the correct order .. my neck is killing me!! but otherwise it went ok. Good Luck.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
