Outside temperature sensor
jandjadavy
Unread post by jandjadavy »
How can I find the outside temperature sensor looked in the passenger mirror not there? Citroen Berlingo 2006 1600 HDI Desire Thanks Jeff
x 3306
Re: Outside temperature sensor
On my company van (Pug Partner, 13 reg) it is a little dome on the underside of the driver mirror.
Trainman
(Donor 2018)
x 43
Unread post by Trainman »
Hell Razor5543 wrote:On my company van (Pug Partner, 13 reg) it is a little dome on the underside of the driver mirror.
It's the same on most of the Citroen range, a quick and "cheeky" test is to hold your finger on the "nipple" to see if it registers a change :-D
Steve
http://c6owners.org/index.php
jandjadavy
Thanks but not there in either mirrors.Has anyone got any other suggestions?Thanks Jeff
x 1487
Post up / PM the last 8 digits of the VIN and I'll check in service.citroen - if fitted it does show it in the Driver's mirror. What fault are you chasing?
jandjadavy
NO outside temperature sensor in either mirrors Have you got any other suggestions the VIN no is 93325840 It stopped working OK now but would like to know incase Ineed to replace it.
Thanks Jeff
x 1487
Definitely shows it associated with the drivers mirror. Not exactly clear where it is though, the sensor is just shown free, I wonder if it might be in the fixed part of the housing on the door? Found this on another forum...
Haven't been on here for a while. I did end up changing this and all was OK. Quite a simple job. Carefully lever out the panel on the underside of the mirror containing the sensor [it clips back in afterwards]. Cut the wires off the old sensor. I cut as close to the old sensor as possible as the wires were not very long and I didn't want to make hard work of crimping in the new sensor. Strip the wires back [two on you new sensor and two no the existing wiring] and splice together using two in line splices and a crimp tool [or pliers if you don't have a crimp tool Icon_smile ]
Coil up and excess wire and clip the temp sensor into the plastic base plate you removed at the beginning. Then refit baseplate on underside of mirror. Only slight problem is they have slightly modified the temp sensor shape at the front end and you have to either cut it or file it down at the front end to get the temp sensor to clip in correctly into the base-plate.
jandjadavy
Thanks to Richard W find the panel on the underside of the drivers mirror looks a simple job
Thanks Jeff
x 3306
For anybody who needs to know, the external temperature sensor on a Series 2 Xantia is on the nearside wing mirror, on the mount itself (the part that doesn't move). It also appears to have a small, removable cover which suggests the sensor may be replaceable without the need to dismount the wing mirror itself (but I cannot confirm this).
John Plum
x 5
Unread post by John Plum »
Ah! That explains why after swapping my nearside mirror unit over with one from my old Xantia, the new Xantia took on the atmospheric temperature fault of the old one :-)
Sent from a mobile transmitter.
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
