Drop links
np
Drop links
Unread post by np »
Having PC probs at the moment[:(!]so can only spend about 5 mins a time on it[:(!][:(!][:(!]so its better to ask as aposed to doing a search.Any hints or tips please as i`m changing the drop links Sat.
Thanks[:)]
Stempy
Unread post by Stempy »
You will need an angle grinder or a nut splitter, don't bother trying to undo the nuts, you will be wasting your time, just go straight in with the heavy mob. Other than that a fairly easy job.
nick
Unread post by nick »
It depends how long they've been on there. I changed the droplinks on my Xantia when I first bought it in 2000, then again a couple of weeks ago and all the nuts came off fine both times. Having said that, if they're still the originals at 138k you may well find the nuts won't budge.
x 1431
Make sure you get both front wheels off the ground at the same time, otherwise the twist on the roll bar will make getting the new ones back on 'interesting'....
Give the nuts a go, but don't hesitate to wade in the with angle grinder if they won't play ball easily.
np
Unread post by np »
Just done them this morning.As usual,hardest part was getting the car onto axel stands.Apart from that,all went well.Nice & easy.One came off fine,had to cut the other one off though.Vibration & rattle gone now.A Job well done.Thanks all.
PC to fix now[:(!][}:)][:(]
