C2 still problem starter.
daviemck2006
- x 485
My C2 is still not behaving itself. A new battery seemed at first to cure it, but it is now needing jump started when cold, it drives perfectly and starts itself when warmed up. The old battery out of it is working properly in the Landie. I then thought the alternator might be goosed, so I have had a bit of checking as far as my limited knowledge of things electrical allows. The voltage in the battery is 12.4V when engine off. When running it shows 14.4V. With car running and alternator disconnected the alternator is putting out 14.4V constant. Thats the new battery in the c2. Out of curiosity the Landie shows 12.4V in the battery, which was the one from the c2 cos I knackered the battery from the landie, and also shows 14.4V across the battery terminals whilst the engine is running. I am wondering what to do next for the c2. I need to get it starting of it's own accord from cold. I have a funny feeling that the car is really voltage sensitive, and have a funny feeling that my "new" battery is new old stock and is not as good as it seems. I cant see any date stamps on the battery, and if I were to take it back to the shop would only get another the same which would still give me problems. If the battery is ok and the alternator is ok, whats the next thing? Starter? poor earth to starter? When jump leads connected it starts instantly. I am thinking my next step is get another battery, but I cant afford to keep chucking money at it just in the off chance it will work. I have no faith in the car, which is a pity cos I actually like it, and it would be cheaper to run than the landrover, one has to go in the spring, looks like its the c2 just now.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
OnlineHell Razor5543
- x 3296
Re: C2 still problem starter.
Based on what you have written, I would clean up the terminals of the new battery, and the INSIDE of the clamps. My reasoning for this is that you say she starts instantly with a jump, and you connect the jump leads to the OUTSIDE of the clamps. That suggests (to me, at least) that the rest of the wiring is OK (but we shall see what an expert says). If you were a mechanic you might want something like this;
http://www.ebay.co.uk/itm/SEALEY-BATTER ... 4951011%26" onclick="window.open(this.href);return false;
EDIT; I didn't mean that you weren't a mechanic, just that, as you weren't a garage mechanic it would be difficult to justify the cost for an item that might get used once in a blue moon.
Xantidote
- x 4
I second what James says. Perhaps unwittingly you've answered your own question. It starts with jump leads, pointing to the existing leads and/or terminals as being suspectdaviemck2006 wrote:When jump leads connected it starts instantly.
Martin
1995 Xantia TDLX (deceased
daviemck2006
- x 485
Ok, today I took the battery out and cleaned the terminals and clamps with sandpaper until they were shining. Battery back in, its still at 12.4 volts and thats putting the voltmeter on the clamps. No joy. Jump leads connected off the freelander, still no go. the dash lights are all ok, no funny messages on the dash no clicks or anything, my guess now is starter motor goosed or connections to starter motor gone bad. I need to get someone else to investigate now, my back is really suffering trying all this outside, I have got a chill or twisted the wrong way or something and I am suffering now. This c2 has got to the stage just now that it can sit and rot until my son in law to be can come down and see if he can figure it out. I shall use the freelander until further notice.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 1053
I notice it's a sensodrive, is the dash still showing N when the fault happens, if it doesent know what gear its in the starter wont operate, also the senso models need to see the brake being pressed or the starter wont operate.
just also be aware the sensodrive models need quite a heavy duty battery, probably bigger that the one in your 1.8 freelander.
daviemck2006
- x 485
It's just been looked at again. The diagnosis is that the new battery is no use for the car. The advice is to buy another battery, a decent one, say a bosch s4 and that should cure it. It is showing n on the display so should know it's in neutral, I asked on the c2 owners also, they reckon that cheap batteries are u/s and go bosch. I can get one delivered for £51 so nae too much of a hit. I'm just a bit peed off with my self for buying a dodgy one from the dodgy shop here for 40quid just because it was convenient. The c2 forum says this car needs 12.8 v before it will start.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
qprdude
- x 14
Buy cheap buy dear. Mine cost me £100. 02 p. for the C5 although I could have got one they said was "suitable" for around £75.
Still, I saved £16 by booking Airparks instead of the long stay NCP for my trip in March.
Rick.
2013 Citroen DS 5 D/Sport
daviemck2006
- x 485
If I still worked at airparks I could have parked your car and got a go in a c5 x7, I would have put it in the top carpark to get a longer go. Then I suppose you will take the mrs clioqprdude wrote:Buy cheap buy dear. Mine cost me £100. 02 p. for the C5 although I could have got one they said was "suitable" for around £75.
As for the c2, on the advice of the nice folk on the c2 owners forum I have ordered a bosch S4 battery for the c2. The vauxhall one cost £40, the bosch £47 from eurocarparts and should be delivered on tuesday, with NO surcharge for a remote postcode (40 miles from the oil capital of europe)!!!! I shall see the airport tomorrow, giving my son-in-law a lift to the heliport in the afternoon.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
qprdude
- x 14
You could have picked your battery up at Eurocarparts in Aberdeen. It,s on St. Machar road, just down the street from my brothers company, Mulco Engineering. My son is off with Bristows tomorrow to the North Sea Producer for a few days.
Hope the new battery does the trick. I've booked the C5 into airparks. I will have to cancel the seat memory as I am such a short a*se, the parking guy will probably be crushed to death.
Rick.
daviemck2006
- x 485
I once got into a top spec range rover in the top car park, seat was fully back and reclined a bit further than i would like. I started engine and got squashed. Happens a lot. There was also the most minging Fiat doblo ever, and if you put the fan on for air you got covered in mining crap. Needless to say the new guys always got it to park or retrieve. If one of the parkers in the know parked it then the fan got put on full speed through face vents just for the guy getting it!
It's typical, I had to go out a while today and note through door on return attempted parcel delivery today. I have a doctor's appointment at 9.10 in the morning, hope the courier is not early in the morning. I should only be out for about 20 mins max. A note will be left on the door, so I hope to report on c2 tomorrow.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
qprdude
- x 14
Too late, but I was in past My brothers place next to Eurocarparts yesterday. I could have collected your battery and you could have collected it from me in Inverurie. (and had a wee go of the C5)
Rick.
daviemck2006
- x 485
Battery here, still no go. I need a proper diagnosis. Think now I'm on older cars forever that AA is gonna be joined with home start. Thats probably cheaper than a tow to a garage. I'm saying forever cos doc signed me off for 6 months this morning.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
Fake Concern
- x 65
That's a bit of a blow, is there anyone near with Lexia? Also a bit of a blow regarding the health situation, hope it improves with the weather as we move towards spring.daviemck2006 wrote:Battery here, still no go. I need a proper diagnosis. Think now I'm on older cars forever that AA is gonna be joined with home start. Thats probably cheaper than a tow to a garage. I'm saying forever cos doc signed me off for 6 months this morning.
daviemck2006
- x 485
Going by guesswork the next thing to try is the starter. There's no guarantee that it's the cure, and I can't afford to throw money at it until it goes. Time to join the AA with home start, cheaper than a tow. And just to p**s me off more, EML came on in the freelander today. At least it's still driving perfectly.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
daviemck2006
- x 485
I've not been in a good place the last few weeks health wise and have had a family emergency to deal with too. When I have been in the car the land rover going perfectly. The EML goes on and off at will but nothing seems wrong apart from having developed a slight exhaust blow. Complete new exhaust £60 delivered so won't be pricking about with it. Right now, 3 pm I'm waiting for the AA to help. That's the car one, not the drink one, although I am a member of it too and have been for 10 years+ I shall let u know shortly.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
