Pauls HDI Xantia Exclusive.
citroenxm
Fallen Hero
x 70
Re: Pauls HDI Xantia Exclusive. and it's ongoing issues!!!
Unread post by citroenxm »
Fuel filter a brand new one when I did the injectors and pump etc.
I thought today, would it be the throttle sensor, as its only on the SECOND half of the throttle travel prehaps??
Theres three pins to the rail pressure sensor, which ones do what, I know they are numbered 1 2 3 ...
Cheers for that write up ...
A very sad...
1994 XM 2.1 d auto
x 1475
Scrub the fuel filter then! Don't know the pin out for the pressure sensor, I'll see if I can find out.....
There's not much left really - I think you are going to have to change out the ECU, I can't see there's anything left - although I would clean the regulator first. I wouldn't have thought it was the TPS - but then again you never know!!!
Is yours a 3 or 1 plug ECU?
citroenxm
Fallen Hero
x 70
As per PM. ALL Xantias use a single Plug 188 pin or so.. EDC18 ECus. Even mums Y reg Xantia had the long single plug.
A very sad...
1994 XM 2.1 d auto
taffy
Unread post by taffy »
fps...1 is earth...2 is signal and should be between 0.5v and 4.5v...3 is power and should be 5v...worth a check paul:)
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
and my ecu was edc15 on mine for ref
x 1475
Paul
Worth checking you have a good earth from the regulator I think - occured to me that if this was missing or poor, then the regulator might not perform as it should. What is the % open at idle? Just had mine on and checked it, and it was only about 8-10%. BTW mine does have cruise in the ECU - find out on Tuesday whether it's good news for me or you :-D
citroenxm
Fallen Hero
x 70
Oooo richard, exciting! thats interesting OF Course, id rather see a Xantia remain on the road.
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Richard,
Theres only TWO wires from the pump regulator - neither are earthed to the battery. Pin ONE on the rail pressure sensor is earthed to battery at just 1.5 OHMs, which I thought was low enough.
This first two are Videos:
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
FFS!!! WHY ARE THE PICS SO BIG!!!
Ive changed them to 600x480 in photobucket!!! GRRRRRRRR
A very sad...
1994 XM 2.1 d auto
taffy
they look fine paul least we can see them :)
citroenxm
Fallen Hero
x 70
I dont like the fact I need to scroll across to see the full pic, do you need to Taffy?
A very sad...
1994 XM 2.1 d auto
x 3283
I can see them without scrolling sideways, but I do have a 22" widescreen monitor at 1680 by 1050 resolution!
citroenxm
Fallen Hero
x 70
My Laptop screen Res is 1024 x 768 pixels. I like to have the pic sitting on the topic exactley right when expanded to full screen so theres no sideways scrolling!!
A very sad...
1994 XM 2.1 d auto
taffy
no i can see them fine...can u use ur mouse pad and use two fingers to shrink the size of the screen? like put one finger eather end od mouse pad hold ur fingers on it and push ur fingers towards each other :)
citroenxm
Fallen Hero
x 70
Nooo, XP here Taffy and an ole Dell Lattitude D505.. Old technology here see.. :-D :-D :-D
A very sad...
1994 XM 2.1 d auto
