Peugeot gearbox questions
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi all.
went to see a friend of a friend's 206 yesterday.. previous to her it had one older lady owner and is now only on 66k miles.
clutch replaced 2 years ago, no surprises there,,
present owner complaining of a gearbox issue.,,
box selected fine with engine off, and was ok until engine got warm.. then 3rd was nearly impossible to select, other gears not much better..
no crunching, clutch bite point was where I would expect.. no drag, no slip.
is this likely to be just the wrong type/quantity of oil? I am going to change it on the weekend anyway.
Is the oil change similar to other PSA cars? a drain under diff and a level plug in sideplate? can I fill from reversing or breather?
car is 1.4 petrol 2001 I think
if the oil is not the problem, what else could be? cant think it would be synchro at that mileage, and no crunching at all.. just tricky to select and 3rd, it doesn't go in at all and jumps out, on the first of any attempt?
ideas gratefully received
John
BX
x 19
Re: Peugeot gearbox questions
Unread post by BX »
More than likely the wrong oil was put in the box when the clutch was done. However that usually causes selection to be very difficult when cold. An oil change cannot do any harm. I did a 206 recently. I think I filled it through the reverse switch. Make sure there is no drag on the clutch as that could cause the problems you describe.
Jack one front wheel, engage gear and get an assistant to press the clutch. Try turning by hand the wheel you jacked. Try this both cold and hot.
jgra1
(Donor 2021)
x 36
thanks BX,, will check for drag, and change the oil and tell her to drive it a few days maybe before expecting a change..
John
x 94
Unread post by citronut »
does sound like it could be wrong oil was installed which in turn damaged the box,
i fill all PSA box's through the vent
Regards, malcolm.
jgra1
(Donor 2021)
x 36
I will change it anyway Malc.. but you think it could be too late now :( ?
jgra1
(Donor 2021)
x 36
clutch replaced 06/12 and 75/90 used to refill..but... car only done 1500ml since then!
x 3275
If you have the owners handbook, you might want to check what gearbox oil is recommended. For example, Citroen recommend BV 75W80 oil for the manual gearboxes used by the Xantia (BE3 and ML5T units). Apparently if you use anything else in the BE3 you end up with stripped synchro cones and treacle. You can get 75W80 from Citroen (about £16 for 2l).
demag
x 102
Unread post by demag »
Maybe the clutch was changed originally because of the the 3rd gear issue, not because an old dear was driving it. Might be a duff box anyway.
Sent from my HUAWEI P6-U06 using Tapatalk
Dave
jgra1
(Donor 2021)
x 36
hmm thanks both... gearbox issue only just arisen.. quite sure all psa manual boxes were 75 80.. fingers crossed an oil change cures it.. box feels nice otherwise..
x 94
i use a 75/80 semi synthetic from GSF, it comes in 4.5lt cans, it does states on the label suitable for PSA gear boxs
Regards, malcolm.
flying clutchman
x 3
Unread post by flying clutchman »
If it's a 1.4 petrol it'll be an MA box. If it's only done 1500 miles I can't see that wrong oil is going to cause a problem. No oil however could be the answer, that would give you those symptoms!
jgra1
(Donor 2021)
x 36
yes true..
hoping to tackle this as job 1 tomorrow.. will update...
thanks guys
John
