Citroen technical department contact info
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
In the car license the tire size is 185/65/R15. I want to change it to 205/60/R15 both has almost identical circumference (0.9% difference ). I referred to the Israeli Citroen importer the get his approval ( In Israel the DMV requires that any change will be approved by the car manufacturer or its local importer ) . He get back to me that he can not approve since Citroen never distributed a 2.0 16V with this tire size. Logically there isn’t any logic behind this. Is there any Email with which I can refer directly to Citroen and get ( hopefully ) their approval
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 94
Re: Citroen technical department contact info
Unread post by citronut »
i belive Citroen techical UK have moved from Slough to PSA HQ Coventry
try this
http://www.citroen.co.uk/contact-us/gen ... t-citroen/" onclick="window.open(this.href);return false;
Regards, malcolm.
ACTIVE8
x 6
Unread post by ACTIVE8 »
citronut wrote:i belive Citroen techical UK have moved from Slough to PSA HQ Coventry
try this
So the technical section have gone there, is that just them that left Slough, and if so when, and why?
ACTIVA
x 94
i heard they were moving everything to Coventry
Regards, malcolm.
lancia58
(Donor 2022)
x 8
Hi
The below Email address "Customer Care Department" is the starting point. Hope it will help others
rlc@citroen.com
Zohar
x 3306
Were they moving to Coventry, or had they been sent to Coventry?!?
