Hi Guys. Looking for the back topics on Lexia etc and all seem to have disappeared with the msg - not in the time frame = or similar; also with the "wonder" piece on tracking with innovative use of laser levels...
I'm still having problems using diag box!
Is it possible for the "Lexia" bits to be edited into a "sticky"?
Where have the old topics gone?
harryp
- x 73
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
- x 3306
Re: Where have the old topics gone?
I think they got bored and went off down the pub for a pint and a pie and chips!
- x 5675
All posts are still there. None have been archived for some time although it is probably time they were.
Use Google advanced search and put the forum in the "Site or Domain" box.
- x 695
Thorter's DIY laser wheel tracking is here, starting on page 2, with my version of his system on page 3:harryp wrote:Hi Guys. Looking for the back topics on Lexia etc and all seem to have disappeared with the msg - not in the time frame = or similar; also with the "wonder" piece on tracking with innovative use of laser levels...
http://www.frenchcarforum.co.uk/forum/v ... 0&start=15" onclick="window.open(this.href);return false;
I just searched for "wheel tracking", with my username (since I posted in the thread) to narrow it down and it came up.
That one is worthy of permanent archiving IMHO, for the price of a couple of cheap laser spirit levels, some bungee cords and a few lengths of wood its possible to do an absolutely precise job of the wheel tracking within a fraction of a millimetre the first time - I'd venture to suggest its actually more accurate than the method most laser alignment "experts" use as rolling the car back and forth half a wheel revolution cancels out nearly all sources of error, and is easily 10x more accurate than trying to measure between the tyre beads with a measuring rod or tape.
I was having terrible trouble with the tracking on mine but ever since I set it with this method it has been bang on - steering wheel perfectly centred, pulls to the centre, tracks well and feels good at speed. Well recommended instead of paying chumps good money to mess it up!
harryp
- x 73
My thanks to Razor, Myglaren and Mandrake! Will try again!
Have been setting tracking with a bar - What a performance and already looking for laser levels, Screwfix etc.
Must agree on a "sticky" for the laser tracking; is this a Moderator jobby?
Thanks again guys
Thanks again guys
Regards, Harry
harryp
- x 73
Mandrake, following the link, once again I get an empty page with the response
"No posts exist inside this topic for the selected time frame."
Regards, Harry
- x 695
Just double checked, the link works fine for me. Must be a browser problem at your end!harryp wrote:Mandrake, following the link, once again I get an empty page with the response
Try using a different browser and see if that helps...
harryp
- x 73
Using google - will try another; later!
Regards
Regards
Regards, Harry
- x 3306
The link also worked for me. IE11
- x 5675
Link works perfectly, suspect you have a browser problem.
Try clearing the cache - chicken soup for browsers.
miked
- x 6
Harry,
Click on "User Control Panel" at the top of this page, Then select the "Board Preferences" tab, then select "Edit Display Options" at the left hand side and make sure the "Display posts from previous days:" setting is set to "All Posts". I just tried changing mine to 2 weeks and it resulted in the behaviour you described.
Mike.
Mike.
harryp
- x 73
Mike, brilliant!! Edited the user control panel as suggested and straight in. Wonder what I inadvertently did to screw it up? Never mind, now know the cure. Step one, hopefully now on the way.
Regards, Harry
