Tuning box been off for over a year Full fuel system swap from another car that had NO ISSUES.. fuel filter changed, fuel pump in the tank changed!!
Im working up to dooing an engine harness complete swap next AND Fuel filter HOUSING swap too...
Pauls HDI Xantia Exclusive.
citroenxm
- Fallen Hero
- x 70
Re: Pauls HDI Xantia Exclusive. has PASSED her MOT!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Eddie Nuff
- New User
- x 38
citroenxm
- Fallen Hero
- x 70
With GREAT difficulty at the moment!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
can you get a new harnes then or a secondhand one...maybe even make your own but its time and money...
is it when it gets over 3000 then?
is that under full throttle then or reguardless of throttle position?
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
citroenxm
- Fallen Hero
- x 70
Yes, more so when foot down. Looking at Live data its when ever the Fuel Pressure Ref and Pressure measured goes over 1000 bar!
Keep it under 1000 bar and she is fine.. Ive got a couple of FULL engine harness and one I know had NO issues on the car it came off...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
KP
- x 27
The pressure relates to the speed of the pump so the higher revs will cause a higher pressure.
Maybe the prv is the issue, is it electronic controlled possibly?
taffy
well sounds like its worth a try then
just abit of work to do...wat about 3rd piston deactivator not doing its job properly maybe?
citroenxm
- Fallen Hero
- x 70
Taff swapped the pump!! Worked perfectly on the other car..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
citroenxm
- Fallen Hero
- x 70
It's NOTHING ON THE PHYSICAL FUEL SYSTEM BECAUSE THE PUMP, INJECTORS, RAIL PRESSURE SENSOR AND TANK FUEL PUMP are all of a fully working car!!! So it's something on my car..
The operation works in that when you put your foot down the turns the fuel pressure REF FIGURE up .. then the ecu then adjusts the fueling to meet the ref.. that's how the engine speed in creases..
its hard demands it can't cope with. I can and do slowly climb to 90 kph and she will cruise there as long as it's a slowish increase.. but hard demand.. nope! If this xantia goes to X rally I shall do some demos to anyone there who might be interested to experience it..
there's two things left to change.. well three. The engine harness loom complete, the fuel filter housing, and the actual ecu.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
well fuel filter 5 mins worth a go...can u see fuel flow on lexia i wonder?
taffy
does the eml come on when it dies?
citroenxm
- Fallen Hero
- x 70
Of course it does and the error every time is : lack of high pressure diesel monitor..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
so what about checking the fps wires while giving them a wiggle whilst checking the contunuity maybe?
what else would measure the pressure?
ur right thou it might be ecu as mine s**t it self by what info i had to go on...fuel tempsensor maybe as if it was faulty would it think "hang on the fuels too hot/cold somethings wrong shut it down?
just trying to help u figure this out mate
citroenxm
- Fallen Hero
- x 70
Yes taffy I appreciate that. I'll get there. I've found from the forum that I seem to always be the one that gets the hardest issues that no one else gets so always get to solve them solo. All suggestions made are what I've done. That's when I post up.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
its god Xantia testing you lol! im sure you will mate in the end and i bet ur not the only one its gona happen too
ul get there
ul get there
