faulty injector 1 issues
snoook65
New User
Unread post by snoook65 »
hello everyone and yes am having some problems with my car c3 1.4 16v hdi 8hy model its been to most garages in my local area and nobody can help me :?: fault codes from Citroen are as follows P1169 P0261 P1163 P0263, ALL INJECTOR OPEN CIRCUIT OR POSITIVE OR SHORT CIRCUIT TO EARTH , ecu has been sent away and aperently tested :| injectors been tested !! cylinders tested ,harness replaced auto elec still checking ? this has been going on since sept !!! 8-[ !!! it all started by hitting small dip in road when eml came on 2 beeps and then went off again left it for while and it got steadly worse :( ,so got it looked at they said checked wiring associated with harness and all seemed well for about 4 months then again only it started cutting out :oops: , then linp mode and thats when i got diagnostic tests done just before xmas! ihave looked at all the websites for info ie crank shaft sensor cam sensor ,personally i think its break in wiring some were ?? can anyone help or had similar issues ????
