Lexia should be arriving tomorrow and laptop has fresh install of xp pro waiting.
In the meantime my blue tooth elm327 arrived today and so just plugged it in.
Pulled 3 codes.
P1352
P0102
P0113.
I've cleared them and will see how the journey home from college goes.
I think one code should relate to the MAF but am unsure about the other 2.
Info was sketchy but think it may be glow plug/relay related and a temp sensor.
Any ideas? Struggling to access Google on phone for some reason.
2.0hdi.
TIA.
Fault codes.
aneesh84
- x 29
Re: Fault codes.
P1352- Ignition Coil A primary circuit malfunction, / SID 801 - Pre/Post heating relay circuit- Relay and pre heating plugs not controlled
P0102- Mass air flow or Volume air flow circuit, low input
P0113- Intake air temperature circuit, high input
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
