cachaciero wrote:You need to bear in mind that the Turbo characteristics / performance are mapped in the ECU if the actual Turbo pressure is above the mapped values then you will get an overboost warning, even theoretically at idle if the turbo was cable of producing significant boost at idle gas flow rates which it isn't.
Now with the vacuum disconnected and the Turbo not under control it is quite probably, almost certain, that the Turbo will be able to produce enough pressure in the intermediate rev range to trigger an overboost condition even if the variable geometry diffuser is stuck in a position that is not the maximum boost position i.e fully in.
So in simple terms it is I believe possible to get an overboost at intermediate revs while still having inadequate boost at higher revs due to a sticking variable geometry diffuser.
You said that the maximum pressure you are reading with the Lexia is 1.2 yet the mapping is calling for 1.5 ergo the problem is in the Turbo. or possibly the Electro Valve.
It would be a good idea to check the calibration of the inlet pressure sensor with an external pressure gauge just to make sure the ECU / Lexia is getting a correct
value.
Might also be worth taping into the vacuum line and check that there is no vacuum on the servo under those conditions when you expect maximum boost.
cachaciero
thanks for the input and sorry for the late reply.
"maximum pressure you are reading with the Lexia is 1.2 yet the mapping is calling for 1.5 ergo the problem is in the Turbo. or possibly the Electro Valve."
Lexia shows 2 values, Requested pressure and measured pressure. both stay at 1.2... its not like it reads 1.4 and delivers 1.2. no: it only sees 1.2 as max requested pressure at all times.
so even thou I'm asking 1.4 in the remap, it only translates to 1.2 requested. theres a 1.2 limitation it appears on the ECU. need to find time to go to the mechanic again and remove that.
hopefully that will be it. turbo was checked by a turbo repair house, they said its fine, seals could be better but its not letting that much oil by so, no need to repair they said. the actuator works fine with a manual pressure pump and gauge. we can see the wategate moving freely...
When you say geometry diffuser are you refering to the wastegate actuator right? I can buy a repaired turbo, but these are not common turbos and its a bit more expensive. and would like a bit more clarification thats the issue before spending 600 euros...
The EV was swapped by the egr as they are identical. no difference.
no vacum leaks, that I am sure as we measured it manually with a pressure gauge by tapping into the inlet pressure sensor sensor plug.
i will put it on a dyno soon and see what numbers this gets me.
i tested 80-120 kmh with 4th and 5th gear and got me 8 and 10 seconds.
OEm specs are 8,8 and 11.7 so its definately better than stock.
one thing it bothers me thou: the stock map I had on the car made it feel like s**t. i never tested anything with it, but it was soooo much slower. it was probably doing less than 1 bar max pressure. and I guess this is the key to it. why? probably not a bad idea to put the stock map and check values. but i need time for that.
I need to take lexia out in a long stretch of highway and see the values for turbo pressure above 3900 as this is where it looses punch significantly. ok top speed of 200kmh roughly with close to 4100 Rpms seems ok. I dont expect a diesel engine to produce any power above 4000rpms, certainly not this generation of turbo diesel PSA engines... and read somewhere the 2.2 head doesnt flow well for more than 160hp anyway, regardless of what size turbo you put on it.
dont get me wrong, I'd just like to get to the bottom of this. but no data to compare and these are not common here in Portugal and certainly not for remaps.
but drives fine pulls well after 1500rpms, before that is dead but normal from what i read.
and i'm getting 7.5 litres average per 100km with normal driving, no special care with fuel savings and both short trips inside the city and highway at 140kmh+ so it seems very good for a 2.2.
a mate with a brand new 508 with the 1.6 e-hdi lump is getting 7.2...
thanks for all the help so far!
