AirBag Light + No Horn = Squib?
Northern_Mike
Re: AirBag Light + No Horn = Squib?
No it wouldn't. The light has to illuminate then go off as per the manufacturers specifications.
x 1996
Unread post by Stickyfinger »
Rawce wrote:Air horn in a can taped to the drivers mirror it is then. Or just strap Brian Blessed to my bonnet?
You can borrow the ex-wife.....ANYONE will hear her if you poke her with a sharp stick !
x 1996
waynedance wrote:Air bag light on is an MOT fail but would pass if bulb removed.
Fail unless you fit one of these http://www.ebay.co.uk/itm/TIMER-SWITCH- ... 1034452865" onclick="window.open(this.href);return false;
ONLY ever as a temp measure until the part can be found
Rawce
Unread post by Rawce »
Right, update time.
I spent about 4 hours dismantling and reassembling down to the innards of the Com20000 unit. Why'd it take so long? 2 hours was spent at the first effing hurdle. 2 spanners Haynes!?! I wish! The clips that hold the air bag in place are fairly ok to unclip individually, but get one out and the other just hibernates. Oooohhh, the new and novel swear words I managed to conjure up solving that ruddy nightmare. Here's a pic, should you meet them in a dark alleyway, please stab 'em in the kidneys for me:
Anyway, I finally got the steering wheel off. The black earth cable seemed disconnected, giving false hope of curing my problem:
A quick underside. Is it me or is the Com2000 unit younger than my 52 plate car?
Seems that's the case!
Com3000 finally off, further hope because the brown didn't seem to be properly connected:
Dismantled:
Yes, it was a bit of a balancing act to get it back together, yes all of my endeavours didn't solve the problems, yes I got rather angry, but at least I know what I'm up against. So, it's off to a scrappies for a replacement...
...well, I'm not 100%. Do I just go for the replacement airbag or should I get the Com4000 too?
x 3296
I wonder if the dates shown are the expiry dates (both of the warranty and of the part!). :-D
x 2938
You'll want the Comm 2000 not the airbag.
Rawce
Hah, 2 year expiry? Could be, sounds typical!
I'll go for a recon Comm then. What bit (hopefully in the pics) holds the serial/version number?
x 1489
If you post up the last 8 digits of the VIN we can check for the part numbber - there are LOTS of variants! However, in your fourth picture you can just see the end of a number ending XT - this is the part number you should be able to cross reference this with potential donors.
Rawce
Cheers everyone, luckily I took another photo of the Comm!
Rawce
Apologies for the groin shot!
Rawce
Looks like it's:
122731 70
96542 534 XT
Rawce
Hmmm, not having much joy online. Anyone got any recommendations for finding the the right Comms unit? Thanks.
x 1489
Send me the last 8 digits of the VIN, and I will get the correct Citroen part number from service.citroen, you can then search against this. There are quite a few on e-bay but mostly used at around £70 - new ones vary from £120 - £200 after aftermarket, depending on which one it is. If you intend to keep the car I woulod advoid a used one, as it is likely to suffer a failure again shortly....
Rawce
76284219
Cheers for checking!
x 1489
service.citroen says:
00006242G3 CONTROL UNIT 232.51 GBP 232.51 GBP 279.01 GBP 279.01 GBP 279.01 GBP 279.01 GBP
:twisted:
Not a common part, as the only sensible hit I got on the part number is: http://www.peugeotpartsforsale.com/citr ... -no-6242g3
Yours doesn't have ESP, so fitting will not require interrogation with a Lexia.
