C5 BSI Pinout
Stempy
C5 BSI Pinout
Unread post by Stempy »
Does anyone have pinout or pin function chart for a C5 BSI? I've been trying to trace various niggly faults, one being the non function of the heated seats. Everything measures ok bar the feed to the heat level control switch which comes from pin 22 of the BSI according to the schematic I have. I am assuming this is a control voltage that is only present when the engine is running to prevent the heated seats from draining the battery.
Lexia ponce
x 1044
Re: C5 BSI Pinout
Unread post by wheeler »
Which shape C5 is this for ? Also there are at least 8 plugs on the BSI, which pin 22 are we talking about ?
Stempy
Re: C5 BSI Pinout
This is a Mk1 02 model C5. Not too sure which connector it refers to but the cable marking is 40V BA 1076A.
Lexia ponce
x 1044
Re: C5 BSI Pinout
That will be the 40 way white connector. I'll have a look & see what I can dig out.
Stempy
Re: C5 BSI Pinout
Thanks, and happy new year!
Lexia ponce
