gear position to shown
chamila
Unread post by chamila »
The gear position lights are not working.
spider
x 77
Re: gear position to shown
Unread post by spider »
What car ?
Check the bulb(s) in the instrument panel assuming they are bulbs not leds.
Are any other lights out ?
Andy.
chamila
Its a pug 406 auto .... The entire cluster of lights related to gear are not working in the panel.
spider
x 77
As the instrument panel comes out quite easily on these I'd take that out first and examine the bulbs, something tells me its leds but I could be wrong, for the sake of 5minutes its quicker than any other initial check I think.
No faults ? I don't think its the selector switch as I'd expect a fault if that's signal was awol. Possibly limp home (3rd and reverse only)
Andy.
chamila
I have replace the selector switch due to some other problem and the bulbs of the instrument panel is ok. Is there another way to check the fault.
spider
x 77
I think Planet will tell you what is has really selected ie where the lever is.
Andy.
