hdi ecu
taffy
Re: hdi ecu
Unread post by taffy »
thanks james :)
im not sure whats comming in the kit software wise...iv already got the software downloaded and im running a virtual box with xp(hope it works)as im on windows 7,
cant wait to see what its gona tell me(ish)lol just hope it gives me a good idea atleast to whats wrong :)
just glad i gota a new battery now cause its gona take alot of stick now!
thanks for the help :)
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
Re: hdi ecu
http://www.ebay.co.uk/itm/321257021340" onclick="window.open(this.href);return false;
thats the one ive bought
its boggling me what all the cables are for?what u need jump leads for lol!?
citroenxm
Fallen Hero
x 70
Re: hdi ecu
Unread post by citroenxm »
Unless you know what the correct figures are for a running engine and what EXACTLEY to look for then the lexia ant gonna tell you what is wrong. It will only tell you if the engine management light is on.. you can then read out the faults.
The kit covers the older generation of cars that predate the centrol communication diagnostic socket those jump leads are for under bonnet use for use on bx ax and mark one xm and cx etc... on these cars you acess the ecu Directly via their own two pin plug... thats hat the "jump leads" are for...
A very sad...
1994 XM 2.1 d auto
taffy
Re: hdi ecu
yeah i been having a bit of a read up today
wow thats mad lol 2 pins! glad u told me :)
im quite looking forward to use this..u can do actuator tests which is crazy lol!
x 3302
Re: hdi ecu
The two USB to RS232 cables do the same job (middle left and bottom left), the only difference is their length. The main cable (top right) is the one that goes from the Lexia to the normal diagnostics port. Top left is the 30 pin connector used on the XM (I believe, and other similar age cars), but I have no idea about the middle right cable (although my kit also has one). The main part is the Lexia itself, top middle.
I am running my Lexia on Windows 7 (32 bit), and it works perfectly happily (not in an XP box, but directly under W7). The other software I was on about are the Citroen manuals (which the Lexia doesn't come with), but has a huge amount of information on a lot of Citroens (including the Xantia). However, if you get this software and then try to install it onto the same laptop as you are using for the Lexia (assuming you have already installed the Lexia software), something in the Lexia software gets in the way (I think it is PSAGENT, but check out Mandrakes' posts for better info).
taffy
Re: hdi ecu
oh well if it works on 7 thats even better!
ah right yea that sounds like something i need :)
any idea what the manuals are called?
il see if i can download them and post a link :)
il have a look at mandrakes cheers :)
x 3302
Re: hdi ecu
This is the sort of thing I mean;
http://www.ebay.co.uk/itm/CITROEN-servi ... 3a83447047" onclick="window.open(this.href);return false;
However, on some cars (XM, Xantia S1) there may not be wiring diagrams.
taffy
Re: hdi ecu
right i got you now :)
thanks for that :)
jgra1
(Donor 2021)
x 36
Re: hdi ecu
Unread post by jgra1 »
sorry to highjack chaps..
noticed yesterday that I cannot see all of the parameters on the lexia.. this is because I am running on a netbook with a small screen.. is there any fix for this? I am quite IT handy but..
I can scroll down when there are choices to be made, but not when looking at parameters shown in yellow etc
thanks
john
x 3302
Re: hdi ecu
John, if you wait for Mandrake to read this, I believe that he knows of a way to resolve this problem.
taffy
Re: hdi ecu
why cant u see it all? could u see it on a normaal laptop?
Chris570
x 36
Re: hdi ecu
Unread post by Chris570 »
it's a screen resolution thingy, there is a config file somewhere where you change the Lexia res.
I've never done it so I've no idea where it is but if you grab Mandrake he'll know.
Or go wind him up on his thread, that'll get a reply (maybe not the one you desire though ;))
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
jgra1
(Donor 2021)
x 36
Re: hdi ecu
taffy
Re: hdi ecu
well lexia just turned up :)
installing diagbox hopeing it will run on win7 64 bit...ive read it might not...also people saying that a virtual machine with xp running on win7 can have problems?
but have read of ppl putting win 7 in xp compatable mode...
any advice guys?
taffy
Re: hdi ecu
well ive installed it,running in compatability mode for xp sp3,running as admin,
im just stuck on the selection of application page where it says lexia or scan tool...if i choose it it just reloads the screen and wont let me go any further...im not in the car but ive got lexia plugged into computer?
