Check your POSITIVE batery lead!! PICS ADDED!!
oscar
- x 8
Re: Check your POSITIVE batery lead!! PICS ADDED!!
One thing how did parking get into Battery leads??? must have missed a page
harryp
- x 73
Hi all, As an update, the local citroen dealer wants £132.88 for the positive lead loom for an HDI 110. Collecting mine tomorrow from a very helpful local Auto Sparky. If anyone is interested I can post cost and Name after I pick them up - time is subject to the bus!!
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
DeafOldFart
More symptoms of battery lead failure.... alarm operates spuriously.... and the clock resets to start when the deadlocks are operated!!!! Truly bizarre, these cars.
Just because you can't see it, don't mean it ain't there..... if it floats, flies or fornicates ,you are better off renting
- x 8349
What do you expect? It's a CitroenDeafOldFart wrote:Truly bizarre, these cars.
Be thankful it's not an XM
harryp
- x 73
Picked up lead. They had used the original captive nuts and starter terminal with new battery clamp and leads. Joints and clamp also soldered. Cost £46 which was more than I was expecting, but probably accounts for time removing original bits! Got it from Autolec Telford. Tel 01952 617805 http://www.autoletctelfordltd.co.uk" onclick="window.open(this.href);return false;. Busy w/e so hope to fit soon!! Looks to be a good solid job.
Regards, Harry
harryp
- x 73
update... ignore website, just gives vistaprint ad.
Regards, Harry
oscar
- x 8
Hi theres a seller on flea bay doing complete + lead i guess could use as - also? cover over terminal and boot over other end with that clear helicoil plastic protector round outside £23ish posted.
http://www.ebay.co.uk/itm/310747579154? ... 1423.l2649" onclick="window.open(this.href);return false;
harryp
- x 73
Price seems ok, but 6Ft long, seems a trifle excessive?
Regards, Harry
aerodynamica
- x 215
Hi , Ive been looking at this on my 1993 1.9TD and have a set of replacement terminals ready but have questions about the leads. The Battery positive is quite long - quick measure sees it around 770mm. My problem is that there's a third, quite thick cable comes from the positive terminal in addition to two that go to the fuse box. I guess it is for the pre heaters but not sure - it goes to a junction box at the inner wing. Anyway, I was going to fit ring connectors for these leads but where would you get large enough ring connectors?
Also, if I'm seeing it right the alternator feed looks like it's joined to the battery terminal about 3/4 along its length and looks like a specific OEM part. This looks like I need to find an alternator cable to fit to connect to the starter positive terminal but Halfords don't do cables of this size - largest is 34 amp that looks about half the required thickness.
Any advice? What have others done for this
Graeme
Graeme
Graeme M
harryp
- x 73
Hi, had a quick google on car battery cable, see the following for starters...
http://www.ebay.co.uk/bhp/car-battery-cable" onclick="window.open(this.href);return false;
http://www.autosparks.co.uk/index.php?cPath=85" onclick="window.open(this.href);return false;
http://www.autoelectricsupplies.co.uk/product_list/33" onclick="window.open(this.href);return false;
I may need some myself later as I am awaiting delivery of a "new" xant and it needs work! New cable too.
Btw, the chap who made mine reused all the original terminations except alt and batt ring terminals
Regards, Harry
Regards, Harry
Regards, Harry
aerodynamica
- x 215
Cheers Harry, I'll look into them. G
Graeme M
aerodynamica
- x 215
Right! Changed positive lead, (oil, coolant and LHM change) car starts ok but the glow plug lamp no longer lights - what have I done? Think they're operating despite the light being inop
Graeme M
Rhothgar
- (Donor 2026)
- x 221
Wish I'd have thought if this for a website!CitroJim wrote:Amusing but surely no need to use those rude words as frequently as he/she/it does. It's all a bit juvenile really. Thing is that you can see equally inconsiderate parking anywhere you care to look. It would appear to be the norm sadly.myglaren wrote: Saw that on the Beebs website. They should make a fortune if what we see on this site is any indication. YPLAC!
Disclaimer - no responsibility accepted for anyone offended by the title or terminology.
Jim's correct about this becoming the norm so let's hope the shame of being listed on this website actually makes people think twice when parking inconsiderately especially when taking disabled or parent bays!
got to get off and print some YPLAC flyers - I'm on that mission!
falling-out-with-my-car
- x 25
These are very good for battery leads but remember to buy the adapter
to go in the middle of the standard clamp (if necessary)
http://www.vehicle-wiring-products.eu/V ... ycable.php" onclick="window.open(this.href);return false;
rergards Nigel.
rergards Nigel.
Teesside saxo
Hi
I just joined the forum and flicking through a few posts, some interesting stuff on here. Those pictures are scary of those leads, does anyone know exactly what caused it?
Its ok changing leads etc. but that cannot be right, what if it happens again?
