MK1 and MK2 Xantia front wing compatibility
John Plum
x 5
Unread post by John Plum »
Do you know whether Mk1 and Mk2 front outer wings are exchangeable, swappable, identical?
Cheers
Sent from a mobile transmitter.
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
jgra1
(Donor 2021)
x 36
Re: MK1 and MK2 Xantia front wing compatibility
Unread post by jgra1 »
no John, quite sure they are not ;( - I cant quite remember why not..
others will know ,
if they are, then you may need headlamps from the same mark as the wing..
which may mean bonnet
which could then include bumper etc
erm
x 1484
Yes...and no!
Looks like 2 types for MK1: 1 for V6 / 2.1TD / 2.0T (to accommodate the wider track); and 1 for everything else.
The wider wings for MK1 are then carried over into MK2.
So, anything will probably fit, but a narrow wing from a MK1 car might look a bit odd on a MK2 car (although the difference in track is small IIRC).
John Plum
x 5
Thanks guys; useful information[THUMBS UP SIGN]
John Plum
lankytim
Unread post by lankytim »
I thought only the 2.0HDi 110 and V6 had wide wings on the Mk2's?
jgra1
(Donor 2021)
x 36
if that's true there must be 3 wing width
mark 1, mark 1 wide (and lower spec mark 2) and mark 2 wideboys?
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Yess.... Only the Big Engine'd S1 cars will do for you, thats Xantia V6, Xantia Activa or Xantia 2.1 TD engine'd cars.
ALL S2 Wings have the wider arch though, like "Big Engine'd" S1's.
Service Citroen: S2 have ONLY ONE Wing part number, and so far are STILL available: 7840 J6 for Left
7841 L3 for Right
A very sad...
1994 XM 2.1 d auto
lankytim
Aaah, OK then, but do the lower engined S2's have a narrower front track?
John Plum
x 5
citroenxm wrote:Yess.... Only the Big Engine'd S1 cars will do for you, thats Xantia V6, Xantia Activa or Xantia 2.1 TD engine'd cars.
So, as I get it, the S1 models above would suit as donor for track width and larger wheel arch; With S2s , watch out for certain S2 wideboys, which have an even wider track?
John Plum
addo
Sara Watson's Stalker
x 95
Unread post by addo »
lankytim wrote:Aaah, OK then, but do the lower engined S2's have a narrower front track?
Yes, by about 10mm per side.
