Northern_Mike wrote:In a 2cv, it also manifests itself as sudden disappearance of all brakes followed by bad language and brown pants.addo wrote:This condition manifests as poor clamping pressure, poor releasing, excessive brake dust and often squeaky discs as you drive.
Seizing caliper being slow to release was boiling the fluid. I found out approaching a line of stationary traffic. Judicious use of the handbrake, ramming it into 1st geat and rubbing the nearside wheels along the kerb avoided disaster.
doseour valve
- x 94
Re: Xantia has poor brakes
Regards, malcolm.
martscar
At the moment the car is all good APART from the brakes.There is no either or.I have had my share of running in circles like a headless chicken trying to do a days work and fix the car.I want to find the solution and fix em, job done .Trial and error is a waste of time and leaves you with a pile of parts only fit for the bin.
- x 94
i dont remember is there a bleed nipple on the dosour valve on the XANT?????, the reason i dont remember is as i have never had to bleed from this point yet on a XANT,
but have once in a blue moon dont so on the likes of the BX, which does have a nipple there,
maybe you need another pair of green blood shot eyes to look at it, as you might be overlooking the obvious
Regards, malcolm.
martscar
Exactly what I am thinking.When I bled the brakes I got a small whoosh from the offside rear nipple. I cant say they feel 100% yet but they do SEEM slightly better.I have not seen anything in the book or even heard of this valve but maybe there is an airlock somewhere but no delay in the brakes.If I hit them anything not screwed down ends up against the front windscreen. My question now is ,would air in the rear affect the front.Trouble is I don't want to settle for 75%
martscar
Where and what is a dosour valve please
martscar
doseour valve
Has anyone had any dealings with the doseour valve on a Xantia HDI please
- x 94
the dosour valve is the hydraulic citroens equivalent to a master cylinder on a conventionally braked car,
so its bolted to the bulkhead in the engine bay behind the brake pedal
Regards, malcolm.
martscar
Thanks Malcolm.Do they give trouble usually.I cannot get any info about it at all anywhere,nothing
addo
- Sara Watson's Stalker
- x 95
martscar
Thanks ad, Yes I already found that out and started another thread but nothing.Only mention I have is From : old guy:??? I think but its vague and I still don't know if its bleedable
VertVega
- x 13
Re: doseour valve
Brake control valve (doseur valve) related threads are available in FCF.
What's the problem?
What's the problem?
Onlinemyglaren
- x 5677
Re: doseour valve
Look at these threads, loads of info there.
martscar
Re: doseour valve
Well brake pressure seems low,could this be responsible do you think.Not leaking as far as I know
VertVega
- x 13
Re: doseour valve
You can start by checking the condition of the brake pads. Fronts first and then rear ones.
Front:
- Check if both pads have about same thickness remaining,
- Traces of any unusual carving, grooves formed on the disk
- Is the caliper sliding easily. If not some brake grease under the seal.
Rear:
- In addition to above first two items, check if the top parts of the brake pads are touching each other.
The pads might be carved like a profile of upside down "L" letter. This happened once with mine.
Finally brake bleeding would do fine, especially the rear dead ends will be free of air bubbles.
Spheres, Hydraflush and Brake Bleeding --> http://www.frenchcarforum.co.uk/forum/v ... 22&t=24595" onclick="window.open(this.href);return false;
As you might have noticed I have not mentioned anything about the doseur valve
Front:
Rear:
martscar
Re: doseour valve
Thanks for your trouble but I have done everything an d am now down to last resort,the doseour valve.50% or so is what the MOT fella said,might be a bit better now but why
