The suspension fluid is in the black plastic tank. I have had mine open several times with no adverse effects. (not with the pump running of course). If you open it, you must be sure to thoroughly clean around the cap first, and ensure that NO foreign bodies get into the tank.
Again, search the forum for topping up the fluid etc.
C5 Suspension
qprdude
- x 14
Re: C5 Suspension
Rick.
2013 Citroen DS 5 D/Sport
qprdude
- x 14
Re:
Does the X7 have a mechanical sensor?addo wrote:It's quite common for the rear sensor here to wear out; couldn't rule the front one out of contention on this basis.
Rick.
- x 5677
Re: C5 Suspension
Perhaps it was a consultant surgeon masquerading as a mechanicqprdude wrote:£95 an hour? Are you sure you're in Yorkshire and not Knightsbridge?
qprdude
- x 14
Re: C5 Suspension
myglaren wrote:Perhaps it was a consultant surgeon masquerading as a mechanicqprdude wrote:£95 an hour? Are you sure you're in Yorkshire and not Knightsbridge?
Better that than the other way round Steve.
Rick.
- x 5677
Re: C5 Suspension
I believe that there are a few of those floating around too.
- x 1056
Re: C5 Suspension
If the X7 C5 is the same as the early ones then the front & rear sensors are the same, you could swap them round & see if the fault changes to the opposite axle.
