New but doesnt feel new.
IrfanIbrahim
Re: New but doesnt feel new.
From normal, put the car on low, I could get 27+ tick interval, when ignition off and start on low height setting, i could get more than 30 close up to 40. Rear centre sphere had never been change, if it was ruptured could it make the tick interval shorter?
1994 Xantia 2.0I
Keep calm & drive a xantia!
- x 3283
As far as I am aware (but I could be wrong) the anti sink sphere does not have any effect on the tick rate. Only the front accumulator sphere does, and I believe this is because it is fitted to the regulator.
- x 94
thats because one of the functions/by products of the accumulator sphere is it acts as a damper to the regulator switching in and outHell Razor5543 wrote:As far as I am aware (but I could be wrong) the anti sink sphere does not have any effect on the tick rate. Only the front accumulator sphere does, and I believe this is because it is fitted to the regulator.
Regards, malcolm.
IrfanIbrahim
So, the rear sphere doesnt affect the tick rate, Im thinking it could be leaking somewhere or maybe the regulator itself, I will let you guys know if I found out anything, thanks for the info.
1994 Xantia 2.0I
