others will know more
Picasso 2.0L hdi 2002 won't start
jgra1
- (Donor 2021)
- x 36
Re: Picasso 2.0L hdi 2002 won't start
45 does sound a little tight for me.. although its been a while since I went near a cambelt.. sure I used to go for 90 or just under,,
- x 1240
If its too tight it will whine, if it doesn't it probably isn't.
Petert
Petert
dbX
I've just redone it to 90 deg twist. Sounds better to me now. I noticed running the engine without auxiliary belt on (just to check cambelt) the engine seems to misfire, but with auxiliary belt back on it doesn't. Anyway it seems fine now.
- x 1240
Possibly low voltage because the alternator isn't working.
