Hi All
This may be a stupid question but I am asking anyway...
My Dad has a 1.9 TD 1999 S2 Xantia, the battery is toast and won't hold charge, standard procedure the car has been sat for a month or two and it looks as old as the Arc anyway. So, in stock I have a 1985 BMW E30 323i 6 cylinder petrol in stock (for breaking) with a strong battery that I was just going to swap over.
Basically will it suffice, blow up or damage?
A quick online check reveals the 323i may be a smaller capacity 52AH than the TD requires.
Thanks in advance
Battery question
airport
Re: Battery question
For your Xantia 1.9 TD you must use a battery between 60ah and 71ah.
- x 94
check battery types here
BMW E30
http://www.tayna.co.uk/096-Numax-Car-Battery-P1012.html" onclick="window.open(this.href);return false;
and this one for the XANT
http://www.tayna.co.uk/027-Numax-Car-Battery-P979.html" onclick="window.open(this.href);return false;
there chart only goes up top 1998 on the XANT as far as i can see
BMW E30
Regards, malcolm.
Xantidote
- x 5
If the BMW battery physically fits the Xantia, then I'd just try it & see (terminal orientation permitting).
As well as the physical size, I tend to look at battery's Cold Cranking Amps (CCA), though as the CCA of batteries increases, then so does the Ah (in general terms).
The quite popular 027 battery is 190mm height, which my TD originally was fitted with. However, for replacements I've always fitted the 075 size (used to be 065?) which is slightly lower height at 175. This size is more useful for me, as when no longer good enough for the TD, it goes on to another smaller vehicle. The 075 comes in varying CCA ratings, from circa 450 up to about 620 CCA. I tend to fit batteries with CCA of about 550-600 CCA to my TD, and expect a good life out of them.
In comparison to the 075, the 096 is a more powerful battery, but a bit longer, and heavier. I always used to think the bigger the better, but not long ago put my back out lifting a battery out of an awkward location in the boot of a vehicle, so prefer the 075 which I can manhandle with 1 hand (just about
Martin
1995 Xantia TDLX (deceased
- x 94
i was always told you should match the battery to the charging/alternator out/capabilities,
Regards, malcolm.
- x 1412
You have been listening to the wrong people. The size of the battery does not affect the alternator (I could give a long technical answer if required) .citronut wrote:i was always told you should match the battery to the charging/alternator out/capabilities,
To the OP, if it physically fits (double check that the terminals are the right way round) , then it will generally work, but may be a bit sluggish on a very cold morning, and may have. slightly shortened service life.
Duke137
I don't think it would be a problem to swap them, my old man has decided that he will buy a new one now. Costco have a brilliant offer on Bosch S5 series, the best you can buy in my opinion, will probably outlast the car!
Thanks for the input all.
Xantidote
- x 5
You could be right - the Bosch S5 seires have 5 year guarantee, so expect 5+ years useDuke137 wrote:will probably outlast the car
Martin
- x 1047
The bigger the battery the better, as long as it will physically fit (remember if its too tall it could short when you close the bonnet) then shove it in, it wont do any alternator damage or anything like that. I would always go by the cold cranking amps rating as that's the one that really matters.
As far as the bosch batteries go I have never used them myself but all I can say is that the place I use to dump all my waste batteries the bin is always full of them. usually about half the batteries in there are bosch so kind of part of the reason I don't use them.
Xantidote
- x 5
What we don't know: Does that mean a lot of them fail (as they will), or that they're a very popular make?wheeler wrote:As far as the bosch batteries go I have never used them myself but all I can say is that the place I use to dump all my waste batteries the bin is always full of them. usually about half the batteries in there are bosch
Martin
Duke137
What it does mean is that statement is retarded and wouldn't hold up in court!Xantidote wrote:What we don't know: Does that mean a lot of them fail (as they will), or that they're a very popular make?wheeler wrote:As far as the bosch batteries go I have never used them myself but all I can say is that the place I use to dump all my waste batteries the bin is always full of them. usually about half the batteries in there are bosch![]()
I always join the back of a long queue because if that many people are queueing for something it must be good, right?
- x 94
Mr "xantia_v6xantia_v6 wrote:You have been listening to the wrong people. The size of the battery does not affect the alternator (I could give a long technical answer if required) .citronut wrote:i was always told you should match the battery to the charging/alternator out/capabilities,
i did not suggest for one minute the wrong battery would/could damage the alternator,
what i was saying
if to larger capacity battery is fitted for a particular alternator, it will struggle/take a lot longer to fully charge the battery,
and i thought to small a battery for a p[articular alternator would not be good either
Regards, malcolm.
- x 1047
The statement was meant to be open ended for you to interpret however you like...Duke137 wrote:What it does mean is that statement is retarded and wouldn't hold up in court!Xantidote wrote:What we don't know: Does that mean a lot of them fail (as they will), or that they're a very popular make?wheeler wrote:As far as the bosch batteries go I have never used them myself but all I can say is that the place I use to dump all my waste batteries the bin is always full of them. usually about half the batteries in there are bosch![]()
KP
- x 27
Check online suppliers and some local ones first before sipping to costco.
Good spec batteries for my FF are £180+
Same spec varta from a local place is £97 and this is for a varta/Bosch s5 020 type
- x 94
GSF are usually quite reasonable for batteries and they give you £4 quid for you old one
Regards, malcolm.
