The XM runs perfectly now! Certainly feels like it has got more get up and go. It's a lot smoother aswell. Almost as if the engine isn't connected to the passenger compartment.
The only problem I've got is with the ABS, the light won't go out. It does it's flickering when the ignition is turned on so I assume the ECU is doing something. The Lexia doesn't have any communication with the ABS ECU, it did before the engine rebuild.
I've visually checked the fuse in the passengers compartment and the one in the engine bay. It's got to be either something I've not plugged in properly or that I've damaged the ECU somehow.
I'll check the connectors tonight but where would you look after that?
XM ABS light not going out, no comms with Lexia
red_dwarfers
- x 58
Kev
'19 C4 Cactus 130 Flair
Chris570
- x 36
Re: XM ABS light not going out, no comms with Lexia
I believe when i saw it you'd taken the abs block off?
It might be the connections down there that are the issue. That's where i'd look.
Good news about the engine though
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 1056
Check the green relay in the box behind the n/s headlight, very common for the relay pins & holder to rot away, normally when you try to pull the relay out the pins stay stuck in the holder.
- x 8422
And that's not a normal relay either Kev..
May not be that as that is what (indirectly) operates the lamp so if it's flickering the relay may be OK. I'd have thought the relay would have brought the light on solidly...
Sounds like a disturbed sensor is the most likely... Check the front ones after all the work done in that region it's likely a connector has been disturbed.
If it's a sensor just think your lucky stars you have an S2. Prices are not quite so silly as for an S1
Excellent news on the engine finally
Chris570
- x 36
Naughty Jim!CitroJim wrote:And that's not a normal relay either Kev..
If it's a sensor just think your lucky stars you have an S2. Prices are not quite so silly as for an S1![]()
This is more likely to be the ABS ECU either not connected or not getting power if he can't talk Lexia to it!
Naughty step, 5 minutes
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
- x 8422
Maybe not Chris.. That the lamp is flickering is an indication that the ECU is going through its self-test routines or is trying to. As I understand it. May well be barking up several wrong trees...Chris570 wrote: Naughty Jim!
On that basis I'll sit on the naughty step for 2 and a half minutes if that's OK...
If I'm totally off the money I'll sit there for 10 minutes...
red_dwarfers
- x 58
The ABS ECU connector needed unplugging and plugging in again. I did also unplug and replug in the relay.
If I remember correctly from last year or the year before when I had ABS issues, which turned out to be a break in the ABS ECU relay coil, it was logged as a fault on the ECU and there was ABS-Lexia comms. One thing I did notice with that fault was all the wheels were registering at a static silly speed, 39 or 69 mph or something.
Cheers
Cheers
Kev
- x 8422
