After market parking sensors C5
micky707
Has anyone attempted to fit a cheap set of reversing sensors to a C5 phase 11 05 to 07 VTR? how easy is it and do you wire up to the reverse light? And are these cheap ones on ebay any good? cheers
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
2 Pug 306's
Citroen ZX 1.9D
- x 2001
Re: After market parking sensors C5
I have been looking at these as well. Was looking at a set with lights then thought, no need for lights is there ! so will get a set with buzzer only....have you been looking at any types in particular ?
My bumper is pre-drilled, yours |?
Rhothgar
- (Donor 2026)
- x 221
I've got some proper Valeo ones for sale. Forget which particular kit they are.
About £100 from memory.
micky707
No need for lights, just a buzzer, my bumper is pre drilled so cant see it being too difficult, just need to find out how to wire in to reverse light. They are as cheap as £12 on ebay, dont know what they are like though
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- x 2001
Looked at reviews on Amazon, most are basic but do the job as far as I can see...£12-.25
micky707
As long as it prevents me from backing into something ill be happy
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- x 1240
I fitted a set of cheapies to my 406 and they seem to work OK except that there is not a flat enough area on the bumper do set them looking directly rearwards, in consequence they scream at you when they see a blade of grass but allow you to reverse into a wall, I have been meaning to modify them but haven't got round to it. I used the wireless ones, I think they were about £20, it saves running a lead to the dashboard, I found a little removable panel in the end of the dash and managed to pick up 12v from there.
micky707
Forgive my ignorance Peter but to fit I need an earth, link up somehow to reverse light and then find a power source? As you can tell Im not an electrics guy
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- x 1240
You should be able to find the reversing light lead somewhere in the back corner, if you don't have a circuit you can find it with a voltmeter with one lead earthed and a sharp pin on the other one which you can push through the insulation of each wire until you find the one that's only live with the revers lights on. An earth shouldn't be difficult, if you can find something that is screwed to the metal work you can slacken the screw and put the earth connection underneath or, you can find one that reads near enough zero ohms to earth with the pin method.
Getting a supply the dashboard end is difficult without knowing the electrical lay out of the electrics.
hamster99
Hi MIcky
Are you sure you don't already have the wiring loom connections on your C5 anyway?
My 2005 VTR had sensors front and back and displayed on the front screen.
In my experience the C5 tends to have the wiring for all the options, they just don't fit everything depending on model purchased.
A number of forum members have retro-fitted cruise control in this way.
Rob
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
- x 2001
Is there not a control ECU for the sensors..?? Anybody got info on what is needed to "factory fit" parking sensors ? so we could work out the parts needed to be scrumpedAre you sure you don't already have the wiring loom connections on your C5 anyway?
micky707
Thats interesting if it is set up, when it dries up I shall take a look, the holes are there so thats a start, I did take a look at someone fitting a set on a Toyota and it looked pretty simple, just wire up to the reverse light, find an earth and your done.
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- x 2001
micky707
Looks good Sticky but Im non the wiser
Micky
2 Pug 306's
Citroen ZX 1.9D
2 Pug 306's
Citroen ZX 1.9D
- x 2001
And I am ??....
....not.
I hope someone here can help point to the correct components to check for (or who knows if they are fitted and just need sensors plugging in) to see if it would be better to go to a scrap yard and get the necessary bits ....always nicer to have original fixtures.
