Xantia HDi Headache.. CURED with some injections...
citroenxm
Fallen Hero
x 70
Re: Xantia HDi Headache..
Unread post by citroenxm »
Fuel pressure ref is connected to the throttle and basically when you put your foot down it rises then the fuel measured is what the ecu has increased to make your engine go faster.... a minus occurs when you say demand 500bar in the reference and the fuel measured is 480bar this results in a -20 bar reading in the diff between actual and ref box....
A very sad...
1994 XM 2.1 d auto
c.morewood
x 55
Unread post by c.morewood »
Just a thought.. and I know its about a different car.. BUT when I owned a C2 for a short time, it would cut out under acceleration, very embarrasing if you'd just come off a roundabout or halfway accross a junction, but wouldn't require the key to restart. It was down to air in the fuel line.. easy to see as there was a bit of clear fuel pipe by the rubber priming pump. I solved it by replacing all of the plastic fuel hose. Sorry if I'm pointing you in the wrong direction Paul. But its something I didn't work out for a few months.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
citroenxm
Fallen Hero
x 70
Appears to be problem solved...
I managed to swap the injectors and a a fuel filter element from the hdi 90 and although the fuel pressure still varies on idle the 40 mile drive home has now resulted on no issues or no cutting out or anything.
It appears then it was either injectors or fuel filter.
THANKYOU TO ALL WHO POINTED TOWARDS INJECTORS it had to be but i was optimistic..
But looks like it was. Originals had 260k on them. These in now have 190k so we shall see how long they last.
A very sad...
1994 XM 2.1 d auto
c.morewood
x 55
Congratulations Paul, I can hear the sigh of relief from here!!
'94 Fiat TipoTd 40K
jgra1
(Donor 2021)
x 37
Unread post by jgra1 »
Paul Fix mine!!!
citroenxm
Fallen Hero
x 70
Get it up here john we will have a look.... 8-) :roll:
Thanks chris yes.. massive releif!! But will feel better later when i know for sure if we go out again later. I always imagine it as a one off till ive used it a few times..
A very sad...
1994 XM 2.1 d auto
Xantidote
x 5
Unread post by Xantidote »
But it can't be all the injectors surely. Presumably one was mis-behaving and dropping the pressure in the high pressure rail?
Martin
citroenxm
Fallen Hero
x 70
The theroy is, they have all been in since new, ALL done 260k, so why p i s s about with one, lexia showed the flow rate as all roughly the same, so I decided to stick ALL four matching from the other engine in...
Deafenatly sorted. Been out again this evening, no problems. Not keen on starting, but this is looking like heater plugs, as she starts much better when hot..
A very sad...
1994 XM 2.1 d auto
x 8391
Re: Xantia HDi Headache.. CURED with some injections...
Brilliant news Paul :-D Excellent!
KP
x 27
Unread post by KP »
Super news Paul :)
Are you going to try the injectors to narrow down which one has failed at all or just sling the lot as they are circa £50 each in used nick if they just need a refurb to be good again?
citroenxm
Fallen Hero
x 70
Ive just swapped them all over.. ill lable mine up as f o o c k e d and put them aside.. not got time to arse around with them.
A very sad...
1994 XM 2.1 d auto
