Fully Loaded C5, but no phone!
x 3281
Re: Fully Loaded C5, but no phone!
According to the packaging Tesco uses the O2 network.
qprdude
x 14
Unread post by qprdude »
sprout wrote:Well I do hope to hear the quality, eventually :rofl2:
Having tried many things now I stumbled upon this which seems strange :shock: :shock:
Hold down the green telephone button down and after several seconds a message comes up on the screen saying "CHEAT CODE" and is waiting for a number.
WHAT is this???
I'd be wary of entering anything yet. See the warning on the cheat site I found.
http://rt4.wikidot.com/cheat-codes" onclick="window.open(this.href);return false;
Rick.
2013 Citroen DS 5 D/Sport
qprdude
x 14
I don't suppose a BSI reset would help, but it might be an idea to try it as it's unlikely to do any harm.
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
- See more at: http://www.citroenownersclub.co.uk/bsi- ... ieK6o.dpuf" onclick="window.open(this.href);return false;
Rick.
sprout
Unread post by sprout »
WHAT is this???
Thanks for the reply, yeah I had found some info with a text file showing the above list. Nothing in there that I think would be relevant, and I think best left alone :wink:
Current: C5 2008 2.0HDi Auto Exclusive (Ireland born) + VW Touareg V10
Previous Cits: CX2000, BX 1.9L, BX 16V, Xant VSX TD, Xant 2.0HDI (110) Exclusive
Some others: Fords1600E, Capri 3000GXL, Granada Scorpio, Mitubishi Starion Saab's 900, 900 Turbo, 9000 Aero, 2 Jeeps
sprout
qprdude wrote:I don't suppose a BSI reset would help, but it might be an idea to try it as it's unlikely to do any harm.
Thanks for this, not something I was aware of (BSI eset)
I will have a full read at the link you posted 8-)
Richard_C
(Donor 2026)
x 220
Unread post by Richard_C »
I know what you mean about hating things that should work but don't, so expect you will keep at it.
It might be worth a look or posting a question on the gpsunderground forum. Under the manufacturer specific heading there is a very active Peugeot citroen forum with lots about myway and navdrive. As the name suggests it's mainly about satnav but you do see some posts about the phone bit of the system.
Some of the solutions are highly unofficial, but I might get a firmware update for myway from there. Depends how much the dealer wants to do it when I go in for service on Tuesday.
Richard_C
sprout
Richard_C wrote:I know what you mean about hating things that should work but don't, so expect you will keep at it.
Ok, thanks for the advice :wink:
I have not had a reply yet, but can only [-o< someone does either here or there 8-)
How did you get on at the "Stealer's"
Richard_C
(Donor 2026)
x 220
Not well. They were happy to do,it and even had a Citroen tech in that day. Sadly they couldn't connect to the service website to get the firmware. They said they would call which they duly did, and apparently they have a slow broadband which makes it a bit hit or miss. I do know the problem, the villages around here do not have good broadband and we won't get FTTC until 2015. Not sure of that was the real problem but take them at their word.
I think I will go the SD card unofficial route as others on here say it works OK. Scary though.
As the car was over 3 years old the service and new front pads were quite reasonable, I doubt my indie would have been much less and this way there is some goodwill if I have a major post warranty problem.
Richard_C
sprout
Just lifting this up in hope someone with a burst of inspiration can salvage my phone :-D
sprout
sprout wrote:Just lifting this up in hope someone with a burst of inspiration can salvage my phone :-D
Ditto :-D
qprdude
x 14
Nothing to add really, except that I got a new 3G Sony Experia recently with a micro sim. I shoved it and its adaptor into the C5 phone slot and it worked no problem. Picked up the new contacts etc. and no problems sending or receiving calls.
Rick.
sprout
Still never been able to sort this :-(
Thought I would bring it back to the top in hope :-)
qprdude what network provider are you with?
qprdude
x 14
o2
Rick.
