Minor voltage drain. How I do proceed?
Rhothgar
- (Donor 2026)
- x 221
Sylv's car has a tiny but, what is considered to be acceptable, voltage drain. Approx 50mA at rest with everything off.
I have traced it, i believe, to the alarm led that sits below the clock.
The drain is occurring on F8 (ZX) which services, Clock, Interior Lighting, Boot lighting, central locking, alarm and siren.
There is a voltage of 60mV being supplied to the alarm LED connector but when I test the LED side of the connector that is no voltage.
With the alarm in an off state and doors closed, I would not expect to see ANY voltage at the alarm LED.
Would anyone know how to go about diagnosing further from here?
- x 8331
Re: Minor voltage drain. How I do proceed?
Hi Roger,
50mA is absolutely the right figure and is absolutely normal. This is the current drawn by the clock, wireless (to keep the memory alive) and the alarm when the ignition is off and everything else is dormant.
You have no worries sir
Rhothgar
- (Donor 2026)
- x 221
Wireless?
I know it is acceptable. I just wanted to see if I could improve on it.
One new problem that has occurred is that I took all the relays out and lined them up in the footwell. Told Sylv to be careful getting in the car but, surprise, she managed to kick them all over the place.
That's not a problem other than I do not know which now goes where!
I have already blown the audible lights on buzzer.
Wonder if anyone could photograph ZX relays and post. Not sure if Xantia will be in same order.
Xantidote
- x 5
Alas, there is no set order for the Xantia. Sorry can't help with the ZXRhothgar wrote:Not sure if Xantia will be in same order
Martin
1995 Xantia TDLX (deceased
- x 694
Indeed there is no set order and even Xantia's of apparently the same spec and similar year can have different relay configurations.Xantidote wrote:Alas, there is no set order for the Xantia. Sorry can't help with the ZXRhothgar wrote:Not sure if Xantia will be in same order
If they're original relays then the relays and sockets are usually colour coded though.
- x 8331
Yep, the thing we use to listen to the Home Service on the VHF wavebandRhothgar wrote:Wireless?
Sorry, I'm showing my age here
Rhothgar
- (Donor 2026)
- x 221
thanks all.
mandrake. i noticed that but there is one that doesn't match. i think I may have inadvertently put that one in some time back.
does anyone have one of these 3 pin white ones with a buzzer inside, circuit board and what looks like an eprom chip?
i thought it was the lights on audible buzzer but Haynes shows that as a separate entity.
luckily found Chapter 12 on a russian website earlier so have generic wiring diagrams.
- x 5666
Not for much longer, the buggers are killing off analogue radio soon.CitroJim wrote:Yep, the thing we use to listen to the Home Service on the VHF wavebandRhothgar wrote:Wireless?![]()
- x 1240
50 m/a is probably about the self discharge rate for the battery anyway so as long as you don't leave it standing for weeks on end it should be OK.
- x 8331
Now that is a step too far Steve. Do you have an details of the plan? I did hear 2015 once and then heard it had been indefinitely postponed.myglaren wrote: Not for much longer, the buggers are killing off analogue radio soon.
I mean, removing the Home Service (and I suppose the Light and Third Programmes) from proper wireless is just unthinkable in much the same way as the UK becoming a Republic. The Ravens will leave the Tower for sure.
I would imagine the listeners of the Third Programme have got a bit hot under the collar as the quality offered by even high bitrate DAB comes nowhere close to what FM offers. It's like the difference between a really good CD or Vinyl and MP3. OK for Radio 1 perhaps but not for serious music lovers...
- x 5666
It was on the Independent last week. 2018 is the cut-off now.
It doesn't really affect me as I only have 3 radios and only two work, the HK on the computer has no antenna.
Only listen to Classic FM and then not for long as the presenters and adverts become annoying very quickly.
- x 8331
That's OK then. Long way off just yet and I'm sure it'll be postponed again and again..myglaren wrote:2018 is the cut-off now.
Adverts spoil everything Steve. Long may this site be free of them
- x 5666
Yep, one of the reasons I don't watch TV either.CitroJim wrote:That's OK then. Long way off just yet and I'm sure it'll be postponed again and again..myglaren wrote:2018 is the cut-off now.
- x 8331
And why I only watch the BBC. If they ever get them that'll be the end... Their incessant trailers for future programmes are bad enough..myglaren wrote:Yep, one of the reasons I don't watch TV either.CitroJim wrote: Adverts spoil everything Steve. Long may this site be free of them
Xantidote
- x 5
You're so right !!CitroJim wrote:Their incessant trailers for future programmes are bad enough..
Martin
