Where's the diagnostic socket on an 03 Picasso?
Northern_Mike
.... going to stick the Lexia on one at lunchtime for a friend at work. 1.6 Petrol with the "stop, overheating" warning, though it's not. Either the fan resistors or the temp sender I expect.
Anyway, It's raining. I don't want to be rooting around too much! Is it under the column like the Berlingo, or hidden in the glovebox like the C5? Or somewhere else altogether?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Check glovebox. Then pull out centre ashtray and rubber underliner - look there. If no go look at cover under steering column.
x 1484
Re: Where's the diagnostic socket on an 03 Picasso?
Under the panel next to the steering wheel seemingly... http://www.outilsobdfacile.com/location ... ra-picasso
Northern_Mike
Brilliant, same place as the Berlingo then. Top stuff chaps.
