hi all got myself a 2001 Picasso 2.0 hdi 140k runs great but the alarm won`t work right will open the doors this then the next time it wont !! so I would like to remove the old one and fit a new one but alas I need the wiring diagram for the alarm can any one help thanks if you can
arch
picasso alarm wiring
- x 1056
Re: picasso alarm wiring
Ive never seen a picasso with a factory fitted alarm, certainly not any UK spec ones so i suspect the alarm is an aftermarket one or doesent have an alarm fitted to it ?
iroc
hi sorry just read that at the end of the workshop manual it`s the fob that's not reliable to lock and unlock the doors thanks wheeler for the info
arch
arch
2001 Picasso 2.0 HDi 90bhp
- x 1484
iroc
hi all can some one tell me were the interior light switch is for the front door I cant see it at all mmmmmmmmmmmmm cheers arch
iroc
well I think that the front courtesy light is controlled by the instrument module ie through the central locking is this so ??
arch
arch
iroc
hi it`s ok I have it 2 blocking diodes and my problem is solved cheers guys
iroc
hi guys just a wee word to the wise if you are going to fit a alarm you will have to switch off the indicators as they are controlled by the cars security system if you don't it will affect the alarm your fitting ok
cheers arch
cheers arch
