Lexia problems
harryp
(Donor 2022)
x 73
Lexia problems
Unread post by harryp »
Ah, Lexia! I now have one of my own.
Having struggled and read hundreds of posts on problems with Lexia, I do not know if my problem is related to software or the hardware supplied with the leads etc. I am using a s/h laptop bought for sole use of the lexia, 1Meg RAM with XP professional SP3 loaded. Eventually managed to get Diagbox loaded with help from both seller and this forum :) . It is V7.02, and is not connected to the internet. Ign is fully on, all dash lights lit. Should I only have in the Aux position?
On starting asks for the VIN. Select Lexia, then select citroen, Xantia, Xantia2, asks for VIN to be input,VIN entered, asks to select application again. Select Lexia, ”Data access problem, you must close the applications in order to change vehicle”
The svhost.exe then uses 100% cpu. Trying to exit, get the error msg, “the communication card is incorrectly initialised. Tool must be restarted” Validate to switch off tool. Can only exit by using Windows Task Manager to end task, which it does with great reluctance. All cables are tight into sockets etc. Have removed and re-connected usb as recommender in forum posts but to no avail. Seems stuck in a loop, lexia, vin, Data access problem. Svhost.exe still using 100% cpu, but strangely enough can start Diagbox easily, so reckon the task manager is caught up somewhere too.
Any ideas as to whether it might be hardware or software related? I am beginning to fray a little at the edges, well quite a lot actually :cry: . My next port of call may be to get the vendor to load it again remotely as offered, but it seemed to load ok once I realised it needs to be done via the Demon.
I have to come to greatly value and respect the expertise available on this forum and wonder it anyone else has, or knows of, a solution? Thanks for any advice coming this way!
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 94
Re: Lexia problems
Unread post by citronut »
i probably cant help you very much but
firstly i find with mine the DIS-LEXIA interface plugged into the laptop before booting the laptop up,
then at the first stage of entering the DIS-LEXIA make sure it is connected to the car with ignition switched on,
then it should find the VIN No. its self,
mine usually asks for the rp No.
dont know if this is of any help
Regards, malcolm.
harryp
(Donor 2022)
x 73
Re: Lexia problems
Hi Citronut. Thanks for response. I have read that it should find the VIN by itself.
Am taking up the offer of the vendor to check the software load as I have tried (I think) every variation as per the various forums notes, etc. That at least will give me a platform with which to start - hopefully!!
Will post back after the s/w ic checked and I try again! Thanks
Regards, Harry
x 694
Re: Lexia problems
Unread post by Mandrake »
harryp wrote:Ah, Lexia! I now have one of my own.
Doesn't sound like the software is installed properly to me, as the sequence you describe above is not correct for Diagbox 7.02. It almost sounds like the standalone (older) version of Lexia has also been installed, which would probably clash with the version bundled with Diagbox.
The correct sequence for Diagbox 7.02 for a Xantia is:
1) Connect the interface to the USB port (the green light should come on)
2) Launch Diagbox, say no to "do you want to check for updates"
3) Choose Citroen, Xantia, Xantia 2, which will take you to a screen with two options, Lexia and Scantool.
4) Unplug the USB cable from the laptop, wait 5 seconds, plug it back in, wait 5 seconds.
5) Click Lexia and enter the VIN number of the car. This will now launch the Lexia app.
6) Before going to Diagnose turn the ignition key on or start the engine.
I've never seen the Lexia app itself ask for the VIN number, you should only get asked for the VIN number once before Lexia is launched. So either you have the old standalone version of Lexia installed (which did ask for the VIN number itself, as it ran by itself without any Diagbox app) or possibly Lexia is unable to communicate with the car so is asking to verify the VIN number again. (However I have not seen this happen even when I've had the cable from the interface to the car unplugged)
The Lexia app will tend to hang and be difficult to end task if anything goes wrong with communication with the interface. The communication card error is worrying, first check in windows device manager that you have an ACTIA device without any errors displayed when the interface is connected and that you have a solid green light on the interface.
Really hard to know without seeing the hardware first hand, with another working system to compare with and swap to find out whether its hardware or software, as the Lexia software and hardware from different vendors does vary somewhat.
One other thing - have you tried it on another car or tried another Lexia on the same car ?
harryp
(Donor 2022)
x 73
Re: Lexia problems
Have just spent a couple of hours (I think) with vendor remotely accessing my pc. Seems that the latest firmware version does not work with all versions of XP. So after a lot of to-ing and fro-ing I got him to do the simple downgrade, which took quite a while. Fair do's, he spent a long time sorting it out and it appears to be working. Just about to connect to car with mains attached. Damn battery on this hp nc6000 seems only to last about 2 hours. will have to look into that later.... may be a fact of life, still was cheap!! Vendor certainly knows his stuff. UKpolboy - the cheaper version mentioned in many posts. can recommend. I would never have been able to sort this on my own! Will have a quick look now!
Regards, Harry
x 1987
Re: Lexia problems
Unread post by Stickyfinger »
Hope you have it sorted.
As a safety thing, I always would have the car do a good run first to make sure the battery is 100% and I would always have the laptop on charge from the mains....Good Luck
harryp
(Donor 2022)
x 73
Re: Lexia problems
Flattened car battery too last night. Will be removed and on charge in a mo. One thing, Having unplugged before selecting Lexia, it then comes round again. Should I remove and reinsert twice, or only on the first or second time. I'm a little confused. Also, should the ign be in the standby position, or all dashboard lights on? It wouldn't read anything, but probably due to the low (then not known) state of the battery?
Regards, Harry
harryp
(Donor 2022)
x 73
Re: Lexia problems
re-reading Mandrakes fullsome response this morning... Does this mean that 1-5 can be carried out (must??) with the ign off? Once connected, it will be easier with engine running as it will mean a fully charged battery. Can the engine be running when using all diagnostics? Do I need to run Lexia or just go straight into diagnostics? Sadly do not know of any other Xants near me (Telford) so am not able to do the check/swap/compare routines. When remotely connected, I'm sure I remember the Vendor checking everything as he downgraded the firmware to get it running correctly. Stickyfingers idea of a good run would be wonderful, but it is still up on blocks with all brakes off. It's much quieter with the new crank pulley!! Must get this done as another xant arrives tomorrow. Requires a pipe so unless I get this going soon, may have a rebellious SWMBO on hand - not good! .... and the grass gets longer and longer!!
Regards, Harry
x 694
Re: Lexia problems
harryp wrote:Flattened car battery too last night. Will be removed and on charge in a mo. One thing, Having unplugged before selecting Lexia, it then comes round again. Should I remove and reinsert twice, or only on the first or second time. I'm a little confused.
Me too. You only unplug once - just before you launch Lexia. It should not be launching a second time.
The ignition key should be fully on, not in accessory. Most ECU's except the body computer (CPH) are powered down when the key is not on.
x 694
Re: Lexia problems
harryp wrote:re-reading Mandrakes fullsome response this morning... Does this mean that 1-5 can be carried out (must??) with the ign off? Once connected, it will be easier with engine running as it will mean a fully charged battery.
The key can be on or off during 1-5, as long as its turned on by the time you use the diagnose menu in Lexia.
All ECU's can have their fault codes read while the engine is running, the only things that won't work with the engine running are engine ECU actuator tests, and apparently some engine ECU's can't have their fault codes cleared while the engine is running.
Don't know what you mean by this. :?
harryp
(Donor 2022)
x 73
Re: Lexia problems
Mandrake, right, thanks for responses.. The initial panel comes up with Lexia on the top and Diagnose (?) lower down. Should I be selecting Lexia to start and then Diagnose once in?
Regards, Harry
