Apart from hydraulic problem I recently posted, I have also this problem now. When trying to start the car, the abs warning light on, and keep on. I couldn't start the engine.
This has happened before, but usually I just waited for around 5 minutes, the problem solved by it self. I've been waiting for almost 30 minutes now, and the problem persists.
What to do? Please..
Thanks,
Elan
ABS warning light on, can not start the car.
elvito
1995 Citroen Xantia 2.0i 8V
Lighty
- x 35
Re: ABS warning light on, can not start the car.
What car is it ?
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
elvito
Sorry. Xantia 2.0i 8v 1995 with antisink.
OnlineHell Razor5543
- x 3295
I don't know why she won't start, but the following link has the info to test the ABS sensors. It is normally the NSF sensor that fails;
http://www.frenchcarforum.co.uk/forum/v ... 11&t=26012" onclick="window.open(this.href);return false;
elvito
I am aware of that the faulty ABS issues experienced by some of the owner. But from what I read, usually the symptom is the ABS warning light on all the time but it didn't stop the engine from starting. But, I will try to test the sensors first.
Thanks.
Thanks.
Lighty
- x 35
Maybe you have corrosion in some of the wiring or multiplugs, Xantia wiring is a bit vulnerable where it runs along the underneath of the radiator x member, especially at each end of the protective sleeving. Perhaps your ABS & non running faults are linked in this way.
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
