radio wiring for bluetooth
leighton.haynes
Unread post by leighton.haynes »
Hello every1. My dispatch mk3 has an unusual raio harness and the radio controls
The display clock etc. Im trying to install a parrot bluetooth but the aftermarket harness dont work.
I need id of correct pins to connect it up. Any help b appriciated. Cheers
BrianM
Re: radio wiring for bluetooth
Unread post by BrianM »
Might help or might not but when I put a parrot kit into my C5 had to get a live from the fusebox - its a while back now but I think it was the switched live.
Brian
09 C5 Exclusive
x 1044
Unread post by wheeler »
The mk3 dispatch has a 'quadlock' connector on the radio which is the kind of new standard for most manufacturers. If you are fitting a parrot kit you need an additional SOT (sound on top) lead, Plenty available on ebay.
http://www.ebay.co.uk/sch/i.html?_trksi ... &_from=R40" onclick="window.open(this.href);return false;
leighton.haynes
Ive used an adapter harness but mute wire is wrong. ? Noyiced the radio
Is from a 307. What pib is mute?
