What is this small fluid reservoir in Xantia
aneesh84
x 29
Unread post by aneesh84 »
I recently bought a Xantia 1999 HDI. I was surprised to find a small white fluid reservoir in front of the LHM tank saying "use only brake oil". I thought LHM was used for braking.
I found another picture of Xantia HDI chassis and have circled it.
https://dl.dropboxusercontent.com/u/277 ... 20-hdi.jpg" onclick="window.open(this.href);return false;
Can you please check and tell me what exactly is this!
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
aneesh84
x 29
Re: What is this small fluid reservoir in Xantia
http://img71.imageshack.us/img71/88/cit ... ehdmc1.jpg" onclick="window.open(this.href);return false;
Another picture where i find that tank. However in many other pictures on on the internet i dont see it.
Have citroen separated the brake circuit in some Xantias?
C5 2005 2.0 HDI 138
electronmirror
x 30
Unread post by electronmirror »
I'd say that's the reservoir for the hydraulic clutch sealed system. On my Xantia HDI 110 it's fitted in a different place. You are correct, the brakes DO use LHM.
....but, this clutch reservoir in your pictures does use conventional DOT 3 or DOT 4 hydraulic fluid NOT LHM.
Trust Citroen to use two different types of hydraulic fluid :-D
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Xantia 110 HDIs have a hydraulic clutch, on UK models it lives behind the engine near the doseur valve, on your Left drive model it must live there, my UK car has nothing in that place.
aneesh84
x 29
I checked it is full. Does it need changing of oil at specific intervals?
Also I had a MK1 xantia before it, and the effort required to push the clutch pedal was same. Is the hydraulic clutch supposed to make pushing the clutch pedal softer?
C5 2005 2.0 HDI 138
x 94
Unread post by citronut »
aneesh84 wrote:I checked it is full. Does it need changing of oil at specific intervals?
heavy clutch pedal usually means the clutch is on its last legs,
on both hydraulic and cable systems
Regards, malcolm.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
The actual clutch mechanisem is supposed to be a cometely sealed unit with no provision or need to top it up .. certainly on uk cars anyway ..
Theres is a small black topup/vent pot on rhd cars right next to the master cylinder on rhd cars..
A very sad...
1994 XM 2.1 d auto
