parking sensors
Robert12
parking sensors
Unread post by Robert12 »
Hi any one fitted front parking sensors to a Citroen c5 Tourer estate got one of the kits of eBay gadgetman parking sensors would you have them on a switch or wired to the brake light switch
x 1240
Re: parking sensors
Unread post by Peter.N. »
I have been considering it, I have them on my 406 estate, I opted for the wireless ones, they pick up their power supply from the reversing light circuit, all you have to find for the dash unit is a 12v supply. You do have to angle them correctly, dud to the shape of the rear bumper I was unable to get mine exactly parallel to the ground, they are looking down slightly consequently they will scream their head of at a blade of grass but let you reverse into a wall. :shock:
Robert12
Re: parking sensors
The car has already got them on the rear working through the reverse gear, trying to fit a set to the front
Thanks Rob
x 1056
Re: parking sensors
Unread post by wheeler »
Deffo fit them on a switch. when they are first switched on they normally beep meaning they would beep every time you pressed the brake. Also it would mean if you were sitting with your foot on the brake at traffic lights etc they would be beeping constantly if you were a little bit too close to the car in front.
x 1240
Re: parking sensors
Sorry - didn't read the post properly - again :oops:
Old-Guy
x 24
Re: parking sensors
Unread post by Old-Guy »
A previous owner fitted reversing sensors (powered off the reversing switch) to the blue estate but not enough attention was paid to positioning them:
  • 5 in a row pointing slightly down, with
    the middle one behind the towball :shock:
Even with the towball removed, the reversing alarm would beep frantically as soon as reverse was engaged. I did prove to my satisfaction that the problem was the positioning of the sensors by reversing up onto a hump - the frenetic beeping stopped as soon as the tail was in the air.
Needless to say, the system is now permanently disconnected.
x 5662
Re: parking sensors
Aren't standard parking sensors (forward) always active while the engine is running?
vibes
Re: parking sensors
Unread post by vibes »
^At least the speakers are always "on", even when the sound system isn't. Very annoying it is.
In Finland we have this thing called Reilu Meininki
2005 C5 V6 Exclusive A Break
micky707
Re: parking sensors
Unread post by micky707 »
Just got a quote from Citroen for supply and fit Parking sensors to my C5 VTR, £390 for genuine Citroen ones and £290 for a set of Dolphin. Thats just the rear!
2.5hrs labour,
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
Robert12
Re: parking sensors
The ones I got of eBay seem OK the only problems getting the wires through the bulk head can't seem to find
A gromet to put the wires through
Robert12
Re: parking sensors
Update parking sensors fitted now got the wires through the bulk head now its just wear to put the switch or should I get the genuine one
