Hellooo Friends , My vehicle is a Citroen C8 2003 Automatic Model . The car starts fine but will not go into any gear at all. the vehicle is absolutely stationary. Does anyone know what might be the problem. I also have another c8 Citroen automatic model 2004. so am I considering swapping parts to get the 2003 model working first then sort out the 2004 later.
Does anyone have an idea what the problem will be as I am suspecting oil, pump , fuel or a fuse on C8 Citroen 2003 automatic Please help. Any suggestions will help. thanks in advance
citroen C8 Vehicle immobiliser fault message
Lighty
- x 34
Re: citroen C8 Vehicle immobiliser fault message
Does the gear lever move?, maybe brake light switch , if the shifter wont move.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
stevahe
The gear lever actually moves into all the gears but the car wont move itself. It revs but will not move at all. thanks
- x 1055
Does the display on the dash show the gear position changing as you move the lever through the various positions ?
stevahe
I have just checked the car now. No the display on the dash does not show any sign of the gear being moved across the various gear positions. thanks
- x 1055
Is the cable still connected to the lever on the gearbox & is it still moving at the gearbox end when you move the lever inside ?
stevahe
i have just seen a loose blue two pin cable under the bonnet close to engine coming from the I suspect under the fuse box . I will investigate and provide full info tomorrow please. thanks
- x 1055
When i say cable i mean mechanical cable not electrical cable. There is a metal cable that connects the gear lever on the dash to a lever on the gearbox that selects the gears. It souds like this cable is either broken or disconnected at one of the ends.
stevahe
I have opened the gear box cover and checked all the internal wires and cables. They appear ok and well connected and I also noticed that the gear box changes are actually being registered on the dash as opposed to my earlier observations. so it is ok as it changes the gears and it reflects on the dashboard. So my next step will be to check under the bonnet and report back my findings. thanks
stevahe
Please Help. I have used a scanner code reader to find out the vehicle fault and it reads Generic fault code :U0404 MEANING Invalid data received from gear shift control module.
Please help with what it actually mean and exactly what to do . Thanks
stevahe
issue not yet resolved. any help will really help. thanks
stevahe
Now I have anti pollution fault. Pls any suggestions as am not surestevahe wrote:issue not yet resolved. any help will really help. thanks
