Xantia Mk2 V6 Strip down
A place to discuss any upcoming meets, club rallies and general get togethers.
Want to come and help strip or meet up with other citroen owners?
Yes Im coming!
2
40%
Nah i'd rather repair my citroen
0
No votes
Im not sure, do you supply tea?
3
60%
Total votes: 5
Chris570
x 36
Re: Xantia Mk2 V6 Strip down
Unread post by Chris570 »
Both WFA vehicles are fuelled and ready to go with a selection of tools in the boot (no jokes please)
We're both on target for 9am and hopefully the engine will be out soon afterwards :)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
KP
x 27
Unread post by KP »
Cheers guys :) just going to sainsburys soon :)
Chris570
x 36
Just tea is all we need, and a place to put cold drinks :P
Looking forward to it actually
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8411
Chris570 wrote: Looking forward to it actually
Me too :-D I'm supplying my own tea. All I need is a mg, boiling water and some milk...
Chris570
x 36
Might I suggest you bring a mug rather than Magnesium, much better for you.
And you're not having anything from Birmingham either before you start that
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
x 8411
How about a magnesium mug?
x 5672
CitroJim wrote:How about a magnesium mug?
Would that be a Milk of Magnesium Mug?
Good for stomach upsets :twisted:
KP
x 27
Unread post by KP »
Sorry guys I haven't done anything more in the car as since I've got home my head has been pounding :( so the sofa since I got home with the odd got flush and aspirin and paracetamol to help it and they are finally kicking in so in heading to bed now so I can get up early enough to get a shower and other bits sorted and will see you all in the morning and fingers crossed the rain stops!!
x 8411
Hope you're better today Will...
Will be setting off fairly shortly and will see you around 9'ish...
KP
x 27
Unread post by KP »
Team WFA has left the building!
Just got the exhaust centre, cat and downpipe out quickly and some connectors and fuses and relays.
The radio connector with cd changer connector had gone though so will need to get a within diagram to work out how I can get 12v to the changer to get the CDs out as it was built into the rest of the loom for the rear :(
Car supports are now being moves back slowly to allow the car to pivot and I'll then weigh the front down to get at the rear bits.
One door is gone as well as the sunroof pack, engine, gearbox, alloys, interior, condenser , driveshafts...
Further update once I've had some grub and a rest as i tried to lift the car before the pivot was in the right place and that drained me a bit as well so quick rest then final sprint to get hits separated and try and work out how to get it off the drive!!
x 695
Unread post by Mandrake »
Hopefully the coil pack was safely liberated before the engine fell into the clutches of Team WFA :twisted:
KP
x 27
Unread post by KP »
Of course it is :)
x 695
Excellent :) Hopefully it solves the old girls main woes... Its definitely misfiring worse in todays wet damp weather...
x 8411
Mandrake wrote:Hopefully the coil pack was safely liberated before the engine fell into the clutches of Team WFA :twisted:
It has :-D It is perfectly safe Simon and not in the clutches of any member of Team WFA... As far as I know...
The Team WFA raiding party was most successful :-D Thanks Will for your hospitality today and apologies to your neighbours for having to put up with us..
First time I've seen an ES9J4 engine and gearbox removed with the help of an angle grinder!!!
There's precious little of the car left now...
I seem to have returned with more than I intended... The XM is pretty well stacked out.. Most of it's engine crane though to be fair...
KP
x 27
Unread post by KP »
Well I'm shattered now so time to call it a night and soak in a bath and then get an angle grinder to help with the last bits over the next night or two :)
