demag
- x 102
Re: Citrojim's Xantia and XM Tales
Definitely, the bigger the better.
Dave
daviemck2006
- x 485
Softies this far north, usually really soft with only natural ingredients
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8423
The XM threw an ABS wobbly today. ELIT reported RH Front sensor was duff and when checked it certainly was. A new one is on order...
Whilst in there I took the opportunity to pop a new auxiliary belt on as the old one looked to be not in the first flush of youth but actually was not as bad as it looked. Still, it's a critical belt and that job is now done..
As that and the sensor needed the mudshields removed I was able to check the bumper mount and sill end for rust. Nowhere near as bad as feared but a little migginess and new metal will be needed at some time in the future in all the usual places...
I got the old Bilt Hambler Dynax S-50 rust prevention wax going on it and filled up the offside sill with the stuff.
I'll do the other side in due course...
Got to look after the old girl...
bxzx16v
- x 34
Your certainly right about looking after the old girl Jim , I've got a couple of bits to sort on the Zx , nothing major just sloppy jack placement which has damaged the factory applied underseal . Why can't people be more careful , all the bits I have attended to previously have been caused by idiotic jacking , rant over
Mark
Mark
- x 8423
My new ABS sensor has just turned up from ECP complete with an enormous free can of QX Maintenance Spray, a WD-40'esque sort of thing.. Delivered before their deadline too
Going to fit it now as that'll mean I can go to Manchester and back tomorrow without the niggle of an ABS light glowing in my face...
- x 8423
Job done, ABS sensor replaced. Light is out
That's not quite such an easy job on an XM
I thought I was going to be lucky as I got the top plastic bit moving... Or so I thought...
It was just the top and that came away leaving the sleeve in the hole.. A punch and cold chisel soon saw it off...
Putting the new one in was scary. It's so tight in the hole despite me cleaning the hole very carefully and making sure all muck and rust was banished. I gently and gingery tapped it in and all is good
I was really worried how hard I was tapping it though..
The Xantia is a piece of cake in comparison.. Think Xantia rear and that's what XM fronts are like..
addo
- Sara Watson's Stalker
- x 95
Chris570
- x 36
Re:
Gitaddo wrote:Amazing; they just don't rust here and my 605 fronts were a doddle to remove.
Jim, my XM ones were exactly the same so no worries, i had to encourage mine in as well, and they're still happy
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
KP
- x 27
Chris you left a bottle of bubbley stuff here! only noticed at about 10pm as i crawled to bed after i lifted the car onto some new brick plinths!
Chris570
- x 36
Have it as a present
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
KP
- x 27
Cheers
Cant drink the stuff myself but sure i can use it as a mixer at a party sometime soon
Chris570
- x 36
Well, there we go
I got the engine and gearbox out of the boot this morning, the car is much happier now it's not got all that weight behind the rear axle!
2006 C5 HDi 170
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
KP
- x 27
Should have fitted some dodgey rear tyres and practised your drifting in the current weather on some nice oil roundabouts
4 wheel drifts are much much fun
- x 8423
It's been a long time... Things have conspired against me doing a lot either on here or on the cars recently so no real news...
Generally all three have been behaving themselves but you can just tell they were feeling a bit neglected and both the XM and the Activa threw little tricks to force me to give them what they craved...
In the case of the XM it was a soft front tyre. I don't know why but every now and again the offside front decides it hated being blown up to 2.4 bar and takes itself down to 1.8. Totally randomly and for no reason as far as I can see. I blow it up and it'll hold for weeks at 2.4 bar before again, when it feels it's being neglected, let a load of air out.
I can't explain that one...
The Activa has a much better way of doing it. She's been parked up of a couple of weeks whilst the V6 Xantia has been doing daily duties and I can only assume Activa is jealous because I've bought the V6 a little present. I can't see any reason for Activa to be jealous as she already has one but you know what these cars are like
Anyway, I woke the Activa up from her slumbers this morning and she greets me with an ABS light
Later I put the ELIT on her and ELIT declares it's the right-hand REAR sensor. Arrrgh
I try clearing the fault and it cleared. So far, has not reappeared...
I am bracing myself for a rear sensor replacement escapade. I bet the fault will not stay away for long...
Cars
Just like kids
Cars
