Parking sensor advice please
Bandit12
x 12
Unread post by Bandit12 »
Been driving my C5 exclusive automatic for a few months now and love it!
However I noticed an intermittent fault with the reverse sensors. Occasionally on selecting reverse the warning module gives a constant tone regardless of how far away or close I am to any rear obstacles. This tone does not change until a forward gear is selected when it turns off. Sometimes selecting reverse again it will work properly and sometimes not.
Was wondering if this was a common prob that can easily be fixed ( a sticky switch which can be cured with a quick squirt of WD40 he asks hopefully:-)). When Ben 82 put the car on his lexia a couple of months ago we did not notice any error codes relating to it.
I have noticed the problem was quite frequent when I first picked up the car and is now very occasional but still annoying.
Any help/ideas are always gratefully received
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
qprdude
x 14
Re: Parking sensor advice please
Unread post by qprdude »
I take it you have cleaned the sensors from road dust etc. Don't know if yours are distance adjustable or not' but I think mine are on the x7
Rick.
2013 Citroen DS 5 D/Sport
Bandit12
x 12
Yes the parking sensors are regularly cleaned along with rest of the car. The distance is fixed to give intermittent beep from 1.5 metres and a solid beep from half metre.
It had a tow bar fitted professionally last year. Got lots of paperwork from some towbar and caravan specialist giving towbar and fitting costs and even got some wiring diagrams thrown in. I do not think the tow bar is an issue as the system works properly most of the time just plays up occasionally.
Bandit
qprdude
x 14
Someone on here had an intermittent problem too, but only while reversing down his drive. I think the sensors might have been tilted slightly downwards, and were picking up a response from the ground where the end of the drive changed angle to meet the pavement. My system shows which sensor is tripping the alarm, which means I know if one is not performing correctly.
Rick.
Ben82
x 7
Unread post by Ben82 »
Random thought, could it be something that's cured by the good ol' curer of a lot of electrical ailments...the BSI reset?
Can't remember if it's something handled by the BSI or not though.
2004 Citroen C5 3L V6 Auto
