2.0 hdi running rough white smoke fault codes...
cc101
Re: 2.0 hdi running rough white smoke fault codes...
Unread post by cc101 »
No problem, guarantee that was the problem, timing out valve hit piston and broke rocker like it should do but NOT when I had a hdi! Make sure she's all timed up correct in the cam timing holes. Well done.
Xantia 1.9 TD 1993 (sinker)
x 8306
Delighted you've found it Taffy.. I expect the rocker was initially weakened when the pump went and then lost the will to live on the restart...
taffy
Unread post by taffy »
yea I think it must off...all those fault codes thou..goes to show The ecu knows a lot :)
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
all done and finally running agsin!! Oh happy day! Thank you so much for your help guys I couldn of done it without you!
cc101
Well done, bet you were over the moon when she fired up!
x 8306
Taffy - Fantastic :-D =D>
taffy
Ah mate I felt a tear after all we been throu! She's purrin real sweet :) jus had an incodent with high pressure hose by The pump iv had to cut it short as The rubber had split but all good now...thinkin it might have been suckin air in hence my problem with constantly ticking...mot next new windscreen bottom ball joints and tyres and Ishes bk! :)
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Well DONE Taffy, Deafenatly deserves an applause.. =D> =D>
You have worked well,
A very sad...
1994 XM 2.1 d auto
taffy
thanks paul :)
