You know, we'll soon have you extolling the virtues of the vi editor at this rate
Raspberry Pi anyone?
- x 8391
Re: Raspberry Pi anyone?
Splendid stuff Xac..
Xaccers
- x 188
I use nano
DIY sphere tool
DIY sphere tool
- x 695
I was about to say the same...Xac wrote:I use nano
Scrolling, insert typing, cut and paste, search, what else do you need ?
Xaccers
- x 188
I vaguely remember vi from my days at uni, where I lost my network access for 2 weeks for mudding.
DIY sphere tool
DIY sphere tool
Ben82
- x 7
I actually switched from nano to vim about a year or so ago, for one main thing, syntax highlighting
(yes nano has some, but not as extensive as vim)
I only know a handful of vim commands, but its enough to get me by
2004 Citroen C5 3L V6 Auto
- x 8391
That's a girl's editorXac wrote:I use nano
I jest. I only use vi because some of the systems I work on have nothing else so familiarity is essential and regular use of vi is essential so as not to inadvertently make a dog's breakfast of something critical.
I even have gvim (a port of vi to Windows) installed on some of my Windows machines... Just for editing stuff destined for the Unix world as Notepad can occasionally have undesirable effects when editing some Unix shell scripts...
I like nano. It's good.
Never ever used emacs...
Xaccers
- x 188
Jim can you cast your eyes over this code
I should be able to add
and have it display The rain in spain on the LCD right?
print(message) would do that.
Code: Select all
from i2clibraries import i2c_lcd
from time import *
# Configuration parameters
# I2C Address, Port, Enable pin, RW pin, RS pin, Data 4 pin, Data 5 pin, Data 6 pin, Data 7 pin, Backlight pin (optional)
lcd = i2c_lcd.i2c_lcd(0x27,0, 2, 1, 0, 4, 5, 6, 7, 3)
# If you want to disable the cursor, uncomment the following line
# lcd.command(lcd.CMD_Display_Control | lcd.OPT_Enable_Display)
lcd.backLightOn()
lcd.writeString("Python I2C LCD")
lcd.setPosition(2, 3)
lcd.writeString("For the Pi")
Code: Select all
message = The rain in spain
lcd.writeString(message)
DIY sphere tool
DIY sphere tool
- x 8391
I would tend to agree with that Xac. I looked up the declaration and use of variables in Python and that seems to be good.Xac wrote: I should be able to addand have it display The rain in spain on the LCD right?Code: Select all
message = The rain in spain lcd.writeString(message)
Only one way to find out
Xaccers
- x 188
I tried last night and it just displayed: message
Will have to try tonight.
DIY sphere tool
DIY sphere tool
- x 8391
Ummm,
The library that has that function is not following rules. have you looked at the code within the library?
spider
- x 77
Is this the topic for assembly language ?
* looks around *
No, goes back to his assembler
* looks around *
Andy.
- x 8391
By all means Andy... I used to back in Z80/8080 and CP/M days...spider wrote:Is this the topic for assembly language ?
Xaccers
- x 188
Eureka I've done it.
Used a bash script to get the temperature (temp=xx.x'C).
I call that within the python script and chop it down to remove the temp=
DIY sphere tool
DIY sphere tool
- x 8391
Let's see your code then XacXac wrote:Eureka I've done it.
Xaccers
- x 188
The bash scriptCitroJim wrote:Let's see your code then XacXac wrote:Eureka I've done it.
Code: Select all
#!/bin/bash
#get system temperarure and save as 'sysTemp'
/opt/vc/bin/vcgencmd measure_temp > sysTemp
# this creates a file called sysTemp in current directory
Code: Select all
import sys, subprocess
# appends to PYTHONPATH the location of the example codes
sys.path.append("/home/pi/quick2wire-python-api/")
from time import *
subprocess.call("/home/pi/temp.sh")
lcd = i2c_lcd.i2c_lcd(0x20,1, 2, 1, 0, 4, 5, 6, 7, 3)
lcd.backLightOn()
def line1():
lcd.writeString("Current Temp:")
def line2():
fo = open("sysTemp")
str = fo.read()
fo.close()
lcd.writeString(str.strip().strip("temp="))
lcd.clear()
line1()
lcd.setPosition(2, 0)
line2()
DIY sphere tool
DIY sphere tool
